system.tag.importTags
Imports a JSON tag file at the provided path. Also supports XML and CSV Tag file exports from legacy systems.
Permission Type: Tag Editing
system.tag.importTags(filePath, basePath, [collisionPolicy])
Type | Parameter | Description |
String | filePath | The file path of the tag export to import. |
String | basePath | The Tag path that will serve as the root node for the imported tags. |
String | collisionPolicy | The action to take when a tag or folder with the same path and name is encountered. Defaults to Overwrite. [optional]. Possible values include:
List - A List of QualityCode objects, one for each tag in the list, that is representative of the result of the operation. See Scripting Object Reference.
Example #1
# This script will import a .json file containing Sine Tags from the desktop into a folder in the Tag Browser called "Imported Tags".
filePath = "C:/Users/[USERNAME]/Desktop/SineTags.json"
basePath = "[default]Imported Tags"
system.tag.importTags(filePath,basePath)
Keywords​
system tag importTags, tag.importTags
