Version: 8.3 Beta 🚧
system.db.runSFUpdateQuery
Runs a query through the Store and Forward system and to multiple datasources at the same time.
Permission Type: Legacy Database Access
system.db.runSFUpdateQuery(query, datasources)
StringqueryA query (typically an UPDATE, INSERT, or DELETE) to run.
String[]datasourcesList of datasources to run the query through.
Boolean - Returns true if successful and false if not.
Code Snippet
# Example 1: Run through single datasource
print system.db.runSFUpdateQuery("INSERT INTO recipes (name, sp1, sp2, sp3) VALUES ('A Name', 1032, 234, 1)", ["MySQLDatasource"])
Code Snippet
# Example 2: Run through two datasources
print system.db.runSFUpdateQuery("INSERT INTO recipes (name, sp1, sp2, sp3) VALUES ('A Name', 1032, 234, 1)", ["MySQLDatasource", "SQLServerDatasource"])
