system.db.runSFNamedQuery
Runs a named query that goes through the Store and Forward system. Note that the number of parameters in the function is determined by scope. Both versions of the function are listed on this page.
note
Only Update Named Queries are allowed in Store and Forward.
Gateway Scope Syntax​
system.db.runSFNamedQuery([project], path, params)
Type | Parameter | Description |
String | project | The project name the query exists in. [optional] |
String | path | The path to the Named Query to run. Note that this is the full path to the query, including any folders. |
Dictionary[String, Any] | params | A Python dictionary of parameters for the Named Query to use. |
Boolean - Returns true if successfully sent to the Store and Forward system.
Gateway, Perspective Session
Project Scope Syntax​
system.db.runSFNamedQuery(path, params)
Vision Client
Simple Example - Without Parameters
# This example runs a Named Query without any parameters in the Project scope.
# The second argument in the function is NOT optional, so Named Queries that do not require a parameter
# must still pass an empty dictionary as an argument.
# Request the Named Query with an empty dictionary as the second parameter.
system.db.runSFNamedQuery("folderName/myNamedQuery", {})
Gateway Scope Example
# This example runs a Named Query without any parameters in the Gateway scope.
# The last argument in the function is NOT optional, so Named Queries that do not require a parameter
# Request the Named Query to execute.
system.db.runSFNamedQuery("ProjectName", "folderName/myNamedQuery", {})
Simple Example - With Parameters
# This example runs a Named Query while passing some parameters in the Project scope.
# The Named Query is assumed to have two parameters already defined on the Named Query:
# param1 : A string
# param2 : An integer
# Create a Python dictionary of parameters to pass
params = {"param1":"my string", "param2":10}
# Run the Named Query
system.db.runSFNamedQuery("myUpdateQuery", params)
