--- title: "Secrets Management Key CLI Tool" --- # Secrets Management Key CLI Tool > The built-in scripts included on this page are available with the Secrets Management Key CLI tool that is included with each Ignition installation to help manage your Secrets Management system once it's configured. Each script begins with the following command: ## Built-in Scripts * On Windows, use `ignition-secrets-tool.bat`. * On *NIX, use `ignition-secrets-tool.sh`. The scripts are described with the commands required to run. Any of the options for each command are accepted, and can be chosen based on preference. The following commands are available for each built-in script to be used as needed. |Command Options| Description| |--|--| |`-f`, `--force`| Force an overwrite of the target file(s) if it already exists. Ignored if the output destination is not a file or if the same value is used for both input and output argument values.| |`-h`, `--help` | Show the help message and exit.| |`-V`, `--version` |Print version information and exit. | :::caution Working with Redundancy When making changes, make sure that the `root` and `KEK` JSON files are applied to both the Master and Backup nodes in a redundant configuration. If not, the embedded secrets and Internal Provider secrets encrypted on one will not decrypt on the other. ::: ### Generate a New Root Key This script generates a new Root Key and encodes it as a JSON Web Key (JWK). The Root Key is encrypted using the given password or passphrase. ```python title="Usage" ignition-secrets-tool root generate [-fhV] [-p[=]] [-r=] ``` |Command Options| Description| |--|--| |`-p`, `--pwd`, `--pass`, `--password`, `--passphrase[=]`|Password or passphrase to encrypt/decrypt the Root Key, as applicable. See the [Password](#password) section below for how to format the argument value that follows this command, or replaces `[=]`. | |`-r`, `--root=` |Root Key input source or output destination, as applicable. See the [Root Key](#root-key) section below for how to format the argument value that follows this command, or replaces ``.| ### Generate a New Key Encryption Key This script generates a new Key Encryption Key (KEK) Set: 1. A new KEK is generated and encoded as a JSON Web Key (JWK). 1. A new KEK Set is generated and encoded as a JWK Set. 1. The new KEK is wrapped inside the new KEK Set as its only element. 1. The KEK Set is encrypted using the given Root Key. ```python title="Usage" ignition-secrets-tool kek generate [-fhV] [-p[=]] [-k=] [-r=] ``` |Command Options| Description| |--|--| |`-p`, `--pwd`, `--pass`, `--password`, `--passphrase[=]`|Password or passphrase to encrypt/decrypt the Root Key, as applicable. See the [Password](#password) section below for how to format the argument value that follows this command, or replaces `[=]`. | |`-k`, `--kek=` |KEK Set input source or output destination, as applicable. See the [KEK Set](#kek-set) section below for how to format the argument value that follows this command, or replaces ``.| |`-r`, `--root=` |Root Key input source or output destination, as applicable. See the [Root Key](#root-key) section below for how to format the argument value that follows this command, or replaces ``. | ### List the Key Encryption Keys This script lists Key Encryption Keys (KEKs): 1. A password or passphrase is first loaded to decrypt the Root Key. 1. The Root Key is loaded next to decrypt the KEK Set. 1. The KEK Set is finally loaded last, and its contents are printed to `stdout` with sensitive key material omitted. ```python title="Usage" ignition-secrets-tool kek list [-hV] [-p[=]] [-k=] [-r=] ``` |Command Options| Description| |--|--| |`-p`, `--pwd`, `--pass`, `--password`, `--passphrase[=]`|Password or passphrase to encrypt/decrypt the Root Key, as applicable. See the [Password](#password) section below for how to format the argument value that follows this command, or replaces `[=]`. | |`-k`, `--kek=` |KEK Set input source or output destination, as applicable. See the [KEK Set](#kek-set) section below for how to format the argument value that follows this command, or replaces ``. | |`-r`, `--root=` |Root Key input source or output destination, as applicable. See the [Root Key](#root-key) section below for how to format the argument value that follows this command, or replaces ``. | ### Rotate the Root Key This script rotates the Root Key: 1. A password or passphrase is first loaded to decrypt the old Root Key. * Optionally, a second distinct password or passphrase is loaded next to encrypt the new Root Key. 1. The old Root Key is loaded next to decrypt the KEK Set. 1. The KEK Set is loaded last. It is decrypted using the old Root Key. 1. A new Root Key is generated and encoded as a JSON Web Key (JWK). 1. The new Root Key is encrypted using the given password or passphrase. 1. The new Root Key is written to its target output destination. 1. The KEK Set is encrypted using the new Root Key. 1. The encrypted KEK Set is written to its target output destination. ```python title="Usage" ignition-secrets-tool root rotate [-fhV] [-p[=] | [[--pwd:in [=]] [--pwd:out[=]]]] [-r= | [[--root:in=] [--root:out=]]] [-k= | [[--kek:in=] [--kek:out=]]] ``` |Command Options| Description| |--|--| |`-p`, `--pwd`, `--pass`, `--password`, `--passphrase[=]`| Password or passphrase to decrypt the old Root Key and encrypt the new Root Key. See the [Password](#password) section below for how to format the argument value that follows this command, or replaces `[=]`. | |`--pwd:in`, `--pass:in`, `--password:in`, `--passphrase:in[=]`| Password or passphrase to decrypt the old Root Key. See the [Password](#password) section below for how to format the argument value that follows this command, or replaces `[=]`. | |`--pwd:out`, `--pass:out`, `--password:out`, `--passphrase:out[=]`| Password or passphrase to encrypt the new Root Key. See the [Password](#password) section below for how to format the argument value that follows this command, or replaces `[=]`. | |`-r`, `--root=`| Root Key input source and output destination. See the [Root Key](#root-key) section below for how to format the argument value that follows this command, or replaces ``.| |`--root:in=`| Old Root Key input source. See the [Root Key](#root-key) section below for how to format the argument value that follows this command, or replaces ``.| |`--root:out=`| New Root Key output destination. See the [Root Key](#root-key) section below for how to format the argument value that follows this command, or replaces ``.| |`-k`, `--kek=`|KEK Set input source and output destination. See the [KEK Set](#kek-set) section below for how to format the argument value that follows this command, or replaces ``.| |`--kek:in=`| KEK Set input source. See the [KEK Set](#kek-set) section below for how to format the argument value that follows this command, or replaces ``.| |`--kek:out=` |KEK Set output destination. See the [KEK Set](#kek-set) section below for how to format the argument value that follows this command, or replaces ``.| ### Rotate the Key Encryption Key This script rotates the Key Encryption Key (KEK): 1. A password or passphrase is first loaded to decrypt the Root Key. 1. The Root Key is loaded next to decrypt the KEK Set. 1. The KEK Set is loaded last. 1. A new KEK is generated and encoded as a JSON Web Key (JWK). 1. The new KEK is added to the end of the KEK Set, which makes it the new primary key. 1. The KEK Set is encrypted using the given Root Key. 1. The encrypted KEK Set is written to its target output destination. ```python title="Usage" ignition-secrets-tool kek rotate [-fhV] [-p[=]] [-r=] [-k= | [[--kek:in=] [--kek:out=]]] ``` |Command Options| Description| |--|--| |`-p`, `--pwd`, `--pass`, `--password`, `--passphrase[=]`|Password or passphrase to encrypt/decrypt the Root Key, as applicable. See the [Password](#password) section below for how to format the argument value that follows this command, or replaces `[=]`. | |`-r`, `--root=` |Root Key input source or output destination, as applicable. See the [Root Key](#root-key) section below for how to format the argument value that follows this command, or replaces ``.| |`-k`, `--kek=`|KEK Set input source and output destination. See the [KEK Set](#kek-set) section below for how to format the argument value that follows this command, or replaces ``.| |`--kek:in=`| KEK Set input source. See the [KEK Set](#kek-set) section below for how to format the argument value that follows this command, or replaces ``.| |`--kek:out=` |KEK Set output destination. See the [KEK Set](#kek-set) section below for how to format the argument value that follows this command, or replaces ``.| ### Reset the Primary Key Encryption Key This script sets the primary Key Encryption Key (KEK) to the key with a given ID. The primary KEK is the key in the last position in the KEK Set. The primary KEK is the key used for encrypting new secrets. 1. A password or passphrase is first loaded to decrypt the Root Key. 1. The Root Key is loaded next to decrypt the KEK Set. 1. The KEK Set is loaded last, and its primary key is set to the key with the given ID. 1. The KEK Set is encrypted using the given Root Key. 1. The encrypted KEK Set is written to its target output destination. ```python title="Usage" ignition-secrets-tool kek primary [-fhV] [-p[=]] -i= [-r=] [-k= | [[--kek:in=] [--kek:out=]]] ``` | Command Options| Description| |--|--| |`-p`, `--pwd`, `--pass`, `--password`, `--passphrase[=]`|Password or passphrase to encrypt/decrypt the Root Key, as applicable. See the [Password](#password) section below for how to format the argument value that follows this command, or replaces `[=]`. | |`-i`, `--id`, `--kid`, `--key-id=`|The ID of the key to set as primary or to remove.| |`-r`, `--root=` |Root Key input source or output destination, as applicable. See the [Root Key](#root-key) section below for how to format the argument value that follows this command, or replaces ``.| |`-k`, `--kek=`|KEK Set input source and output destination. See the [KEK Set](#kek-set) section below for how to format the argument value that follows this command, or replaces ``.| |`--kek:in=`| KEK Set input source. See the [KEK Set](#kek-set) section below for how to format the argument value that follows this command, or replaces ``.| |`--kek:out=` |KEK Set output destination. See the [KEK Set](#kek-set) section below for how to format the argument value that follows this command, or replaces ``.| ### Remove a Key Encryption Key This script removes the Key Encryption Key (KEK) with a given ID: 1. A password or passphrase is first loaded to decrypt the Root Key. 1. The Root Key is loaded next to decrypt the KEK Set. 1. The KEK Set is loaded last, and the key with the given ID is removed from the set. 1. The KEK Set is encrypted using the given Root Key. 1. The encrypted KEK Set is written to its target output destination. ```python title="Usage" ignition-secrets-tool kek remove [-fhV] [-p[=]] -i= [-r=] [-k= | [[--kek:in=] [--kek:out=]]] ``` | Command Options| Description| |--|--| |`-p`, `--pwd`, `--pass`, `--password`, `--passphrase[=]`|Password or passphrase to encrypt/decrypt the Root Key, as applicable. See the [Password](#password) section below for how to format the argument value that follows this command, or replaces `[=]`. | |`-i`, `--id`, `--kid`, `--key-id=`|The ID of the key to set as primary or to remove.| |`-r`, `--root=` |Root Key input source or output destination, as applicable. See the [Root Key](#root-key) section below for how to format the argument value that follows this command, or replaces ``.| |`-k`, `--kek=`|KEK Set input source and output destination. See the [KEK Set](#kek-set) section below for how to format the argument value that follows this command, or replaces ``.| |`--kek:in=`| KEK Set input source. See the [KEK Set](#kek-set) section below for how to format the argument value that follows this command, or replaces ``.| |`--kek:out=` |KEK Set output destination. See the [KEK Set](#kek-set) section below for how to format the argument value that follows this command, or replaces ``.| ## Argument Value Formatting ### Password The password or passphrase argument value can be formatted as follows: * `pass:password`: The actual password or passphrase is password. Since the password or passphrase is visible to utilities (like 'ps' under Unix) this form should only be used where security is not important. * `env:var`: Obtain the password or passphrase from the environment variable var. Since the environment of other processes is visible on certain platforms, this option should be used with caution. * `file:pathname`: Reads the password or passphrase from the specified file pathname, which can be a regular file, device, or named pipe. Only the first line, up to the newline character, is read from the stream. * `stdin`: Reads the password or passphrase from standard input. The same line handling as described for file applies to passwords read from standard input. If no password or passphrase argument value is given then the user is prompted to enter one. This will typically be read from the current terminal with echoing turned off. If this option is omitted entirely, then the value is obtained from the environment variable IGNITION_ROOT_KEY_PASSWORD and if this environment variable is not set, then the user is prompted to enter one. ### Root Key The Root Key argument value can be formatted as follows: * `file:pathname`: Reads or writes the Root Key from/to the specified file pathname, which can be a regular file, device, or named pipe. Only the first JSON element is read from the stream, which is expected to be a JSON object representing the flattened JSON Web Encryption (JWE) serialization of the encrypted Root Key. * `stdout`: Reads or writes the Root Key from/to standard output. If this option is omitted entirely, then the value defaults to `file:$CWD/data/config/ignition/keys/root.json` where `$CWD` is the current working directory. ### KEK Set The KEK Set argument value can be formatted as follows: * `file:pathname`: Reads or writes the KEK Set from/to the specified file pathname, which can be a regular file, device, or named pipe. Only the first JSON element is read from the stream, which is expected to be a JSON object representing the flattened JSON Web Encryption (JWE) serialization of the encrypted Root Key. * `stdout`: Reads or writes the KEK Set to standard output. The same handling as described for file applies to KEK Sets read from standard input. If this option is omitted entirely, then the value defaults to `file:$CWD/data/config/ignition/keys/kek.json` where `$CWD` is the current working directory.
