Version: 8.3
Docker Image Examples
This page contains example run configurations for the Ignition Docker image to demonstrate best practices for specified scenarios.
Deploying an Ephemeral Gateway for Testing​
The run statement below will launch a container in detached mode -d, publishing port 9088 from the host to port 8088 in the container. The container will be named ignition-test and use the 8.3.0 image. Finally, the runtime arguments provided will set the Gateway name -n to docker-test with public address of localhost on HTTP port 9088 and HTTPS port 9043.
docker run -d -p 9088:8088 --name ignition-test inductiveautomation/ignition:8.3.0
-n docker-test -a localhost -h 9088 -s 9043
Multi-line commands
For Linux/macOS/WSL, you can use the backslash with multi-line commands for better readability. You can substitute the backtick ` for Powershell and caret ^ for Windows Command prompt, these characters technically "escape" the newline character, so make sure they are the last character on a given line.
Preserving Gateway State​
When using containers, it is common for stateful applications (such as the Ignition Gateway) to leverage volumes to persist that state across image updates, container remove/create cycles, etc. This can be done by applying a named volume to the /usr/local/bin/ignition/data path within the container. This is especially important if you need to make a change to your container configuration. Since container configurations are immutable, the only way to change it is to stop/remove the old container and start a new one (with a new configuration).
The sample run statement will be similar to the one above, but this time with a named volume gw-data attached to /usr/local/bin/ignition/data within the container. If the volume doesn't already exist, it will be created automatically. Note the additional --pull option to make sure that the latest tag is always pulled before running. Without this, the latest tag is only pulled if one isn't already present on your system.
docker run -d -p 9088:8088 --name ignition-test \
-v gw-data:/usr/local/bin/ignition/data \
--pull always inductiveautomation/ignition:latest \
By using named volumes, you're now able to stop and remove the ignition-test container and create a new one with a different configuration. As long as you attach your volume, your Gateway will start up with all of your tags and projects in their previous state.
Automating the Restore of a Gateway Backup​
You can automate the restore of a Gateway backup on first-launch of your Gateway container. This allows for having a new Ignition Gateway restore to a known initial state automatically, without waiting for the commissioning steps. To leverage this feature, bind-mount a Gateway backup into the container and then use the -r runtime argument to specify the location and command the restore. Additionally, supply the ACCEPT_IGNITION_EULA=Y environment variable to accept the Ignition EULA (see the Licensing section) and bypass that Gateway commissioning step.
-v /path/to/gateway.gwbk:/restore.gwbk \
-e ACCEPT_IGNITION_EULA=Y \
inductiveautomation/ignition:8.3.0 \
-n docker-test -a localhost -h 9088 -s 9043 \
-r /restore.gwbk
What if I restart the container
The Gateway restore will only apply on a fresh Gateway launch. Subsequent restarts of the container will not restore the indicated Gateway backup.
Automate the Commissioning of a Fresh Gateway​
You can automate the commissioning steps that normally require manual user interaction on the very first launch of the Ignition Gateway. By supplying specific environment variables , you can seed the commissioning steps with the required information to start the rest of the Gateway automatically.
-e GATEWAY_ADMIN_PASSWORD=password \
-e IGNITION_EDITION=standard\
-n docker-test
Reading Environment Variables from a file
You can also specify environment variables in the form of <env var>_FILE=/path/to/file in order to have the environment variable value resolved by reading it from a file. This is helpful for secrets management systems within container orchestrators, such as Docker Swarm and Kubernetes.
Customizing JVM/Wrapper/Gateway Arguments on Container Launch​
This example shows how to leverage the supplemental JVM/wrapper args feature.
docker run -d -p 9088:8088 --name args-test \
-e GATEWAY_ADMIN_PASSWORD=changeme \
-n args-test \
-- wrapper.java.initmemory=256 -Dignition.allowunsignedmodules=true \
-Dignition.license.leased-activation-terminate-sessions-on-shutdown=true \
-XX:MaxGCPauseMillis=200
The following demonstrates how to enable the Gateway's Resolve Host Names and Use Proxy Forwarded Headers settings by modifying the entries in the gateway.xml:
docker run -d -p 9088:8088 --name ignition-test inductiveautomation/ignition:8.3.0 -n docker-test -a localhost -h 9088 -s 9043 \
-- gateway.resolveHostNames=true gateway.useProxyForwardedHeader=true
Using Docker Compose​
A common practice is to leverage Docker Compose to start your container and bundle the configuration with other services, such as databases and MQTT brokers. Below is an example docker-compose.yml file that you can create inside of a new, empty folder. The example below incorporates many of the configurability features mentioned in the various sections above.
Compose Example
# Docker Compose Example for inductiveautomation/ignition
# Compose Spec: https://github.com/compose-spec/compose-spec/blob/master/spec.md
services:
# Ignition Gateway
gateway:
image: inductiveautomation/ignition:8.3.0
ports:
- 9088:8088
- 9043:8043
volumes:
- gw-data:/usr/local/bin/ignition/data
# env_file: ignition.env # optionally specify variables in a file, or using `environment:` below
environment:
- ACCEPT_IGNITION_EULA=Y
- GATEWAY_ADMIN_USERNAME=admin
- GATEWAY_ADMIN_PASSWORD_FILE=/run/secrets/gateway-admin-password
- IGNITION_EDITION=standard
- TZ=America/Chicago # see https://en.wikipedia.org/wiki/List_of_tz_database_time_zones#List
secrets:
- gateway-admin-password
command: >
-n docker-test
-m 1024
wrapper.java.initmemory=512
secrets:
gateway-admin-password:
file: secrets/GATEWAY_ADMIN_PASSWORD
volumes:
gw-data:
Once defined, you can bring up the solution using docker compose commands.
Integrate Third Party Modules After an Upgrade​
Third party modules installed through the web interface are automatically routed to the external modules folder within the data volume. This means no special consideration is required for these modules when upgrading Ignition to a newer image version.
However, if you wish to integrate third party modules such that they cannot be uninstalled by the user, use the following example of how to build a derived image with your modules co-located with the built-in modules under /usr/local/bin/ignition/user-lib/modules.
note
If a module is added to the built-in modules location through this method with the same module identifier, that module will route to the external modules folder and effectively "shadow" the built-in module file. For instance, instead of the built-in module loading, the one in the external modules folder with the same module identifier will take precedence.
To start, a module subfolder with the modules we are attempting to integrate will be labeled gw-build. The subfolder will also include a Dockerfile. The docker-compose.yml file needed for this process is located outside of this subfolder. We will be using a docker-compose.yml file similar to the previous example, but instead of using an image tag, we will be using a build tag.
docker-compose.yml
services:
gateway:
build:
context: gw-build
## Specify the upstream version to derive from for the build argument in the Docker file.
args:
IGNITION_VERSION: 8.3.0
ports:
- 8088:8088
volumes:
- gateway-data:/usr/local/bin/ignition/data
environment:
ACCEPT_IGNITION_EULA: "Y"
GATEWAY_ADMIN_PASSWORD: password
IGNITION_EDITION: standard
command: >
-n Ignition-supp-66195
volumes:
gateway-data:
The Dockerfile within the gw-build folder will define the derived image by containing a build argument for the Ignition version. Notice this does not give a default version. This is because the version we want to build is specified and passed through our docker-compose definition. Next, we will add a command to copy the module files from this folder to the user-lib module folder inside the new Ignition image.
Dockerfile
ARG IGNITION_VERSION
FROM inductiveautomation/ignition:${IGNITION_VERSION}
COPY *.modl /usr/local/bin/ignition/user-lib/modules/
With these files defined, we can now run docker compose build to pull the image, perform all derived image build steps, and create the new image.
note
Since docker compose build needs to be run each time a new module is added, you can alternatively add pull_policy: build in the yml file to automatically build each time.
User Migration - Docker Compose​
The following example uses Docker Compose to demonstrate how to migrate the container user and file ownership from the root user to a standard, non-elevated ignition user. If you are instead using the command line, see the next example for migrating users. Your environment may vary, depending on how your container is set up.
User Migration Example (Docker Compose)
# User Migration Example (Docker Compose)
services:
# Ignition Gateway
gateway:
volumes:
- ignition-data:/usr/local/bin/ignition/data
ports:
- 8088:8088
command: >
-n docker-test
volumes:
ignition-data:
  1. Upgrade the container to the latest version by changing the image tag to the version you want to upgrade to:
services:
# Ignition Gateway
gateway:
volumes:
ports:
- 8088:8088
command: >
-n docker-test
volumes:
ignition-data:
  1. Add the IGNITION_UID=2003 and IGNITION_GID=2003 environment variables to update the container permissions:
services:
# Ignition Gateway
gateway:
volumes:
ports:
- 8088:8088
environment:
- IGNITION_UID=2003
- IGNITION_GID=2003
command: >
-n docker-test
volumes:
ignition-data:
  1. Declare the root user (user: "0:0"):
services:
# Ignition Gateway
gateway:
volumes:
ports:
- 8088:8088
environment:
- IGNITION_UID=2003
- IGNITION_GID=2003
user: "0:0"
command: >
-n docker-test
volumes:
ignition-data:
  1. Save the Docker Compose file, then run docker compose up -d.
note
By default, we are using the -d option in our Docker command. While you can also run the command without -d, the option runs the container in detached mode, allowing the container to run in the background even after closing the terminal.
  1. The container will now use the root user when it starts up, but will launch Ignition as a standard ignition user. All of the files in the ignition-data volume have the proper ownership. We can now remove the IGNITION_UID and IGNITION_GID environment variables and the user:"0:0" override:
services:
# Ignition Gateway
gateway:
volumes:
ports:
- 8088:8088
command: >
-n docker-test
volumes:
ignition-data:
  1. Finally, we can rerun the docker compose up -d command to recreate the container. Since we removed the environment variables and updated container permissions, the container will launch with the default user being a standard ignition user.
  2. To check if the user successfully migrated over, verify the process listing and who the user is for each process using the command docker compose exec gateway ps aux in the terminal. Additionally, you can use the command docker compose exec gateway whoami to see who the default user for the container is:
User Migration - Command Line​
The following example uses the command line to demonstrate how to migrate the container user and file ownership from the root user to a standard, non-elevated ignition user. If you are instead using Docker Compose, see the preceding example. Your environment may vary, depending on how your container is set up. The following container is called example-gw and is running Ignition version 8.3.0:
User Migration Example (Command Line)
docker run --name example-gw -v example-gw-data:/usr/local/bin/ignition/data \
-e IGNITION_EDITION=standard -e ACCEPT_IGNITION_EULA=Y -e GATEWAY_ADMIN_PASSWORD=password \
-p 8088:8088 \
-n example-gw
  1. Stop and remove your Docker container using the following commands. Keep in mind that you will need to replace example-gw with your container name:
    # Stop and remove container
    docker stop example-gw
    docker rm example-gw
  2. Modify the container run configuration to declare the root user using --user 0:0 (The UID and GID will both be 0):
    # Declare the root user
    docker run --name example-gw --rm -v example-gw-data:/usr/local/bin/ignition/data \
    -p 8088:8088 \
    --user 0:0 \
    -n example-gw
  3. Update the container permissions by adding the IGNITION_UID and IGNITION_GID environment variables. You can do this by adding -e IGNITION_UID=2003 -e IGNITION_GID=2003 after --user 0:0:
    # Update the container permissions
    -p 8088:8088 \
    --user 0:0 -e IGNITION_UID=2003 -e IGNITION_GID=2003 \
    -n example-gw
  4. The container's Gateway should now be running under a standard ignition user, using a UID of 2003 and a GID of 2003. You can run the following command to count the number of processes running as a standard ignition user:
    # Count the number of running processes under the ignition user
    docker exec example-gw pgrep -u 2003 -c
    note
    There should be 3 processes:
    • the entrypoint
    • the Java wrapper
    • the Java process
  5. File ownership should now also belong to the standard ignition user. You can use the following command to verify that there are no files owned by any other user aside from the standard ignition user:
    # Verify file ownership
    docker exec example-gw bash -c "find /usr/local/bin/ignition ! -user 2003 | wc -l"
  6. Once you have verified file ownership and the user the processes are running under, you can now recreate the container against the new image with the default ignition user (UID = 2003) and update your Gateway to the latest version:
    # Recreate the container
    -p 8088:8088 \
    inductiveautomation/ignition:8.3.<new> \
    -n example-gw
