--- title: "system.historian.updateRegisteredNodePath" description: "Updates the existing historical path for a stored historian node to the newly specific path." --- # system.historian.updateRegisteredNodePath > Updates the existing historical path for a stored historian node to the newly specific path. This function is used in **Python Scripting**. ## Description Updates the existing historical path for a stored historian node to the newly specific path. This function applies to the Core Historian and Internal Historian only. ## Client Permission Restrictions This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.historian.updateRegisteredNodePath(previousPath, currentPath, [blockForResult])` ### Parameters |Type| Parameter| Description| |--|--|--| |String| `previousPath`|The previous path for the historian node.| |String |`currentPath` |The new current path for the historian node. If null, then the historian node will be retired.| |Boolean| `blockForResult` | A flag indicating whether the result should be blocked until confirmation that the update has been attempted. [optional]| ### Returns **List** - A list of [QualityCode](appendix\reference-pages\scripting-object-reference\scripting-object-reference.md#qualitycode) objects. The quality code will indicate success or failure, and if successful, the path will be updated. ### Scope Gateway, Vision Client, Perspective Session ## Code Examples ```python title="Code Snippet" # Update a previously stored path. previousPath = "histprov:Core_Historian:/sys:gw1:/prov:default:/tag:updateNode1" currentPath = "histprov:Core_Historian:/sys:gw1:/prov:default:/tag:updateNode2" system.historian.updateRegisteredNodePath(previousPath, currentPath, True) ```
