--- title: "Vision - Comments Panel Scripting Functions" --- # Vision - Comments Panel Scripting Functions > This page details the various component and extension functions available for [Vision's Comments Panel component](comments-panel.md). ## Component Functions This component does not have component functions associated with it. ## Extension Functions ### insertNote * Description * Called when a note is added. * Parameters * component **self** - A reference to the component that is invoking this function * string **note** - The text contents of the note * string **filename** - The full filepath to the the attachment * string **sticky** - A boolean indicating whether this note should be flagged as stickied * Return * None ### deleteNote * Description * Called when a user clicks the 'delete' link on a note. * Parameters * component **self** - A reference to the component that is invoking this function * integer **id** - The id of the note * Return * None ### unstickNote * Description * Called when a user clicks the 'unstick' link on a note. * Parameters * component **self** - A reference to the component that is invoking this function * integer **id** - The id of the note * Return * None ### downloadAttachment * Description * Called when a user attempts to download an attachment from a note. * Parameters * component **self** - A reference to the component that is invoking this function * integer **id** - The id of the note * Return * None ### canDelete * Description * Returns whether or not a note with the given id can be deleted. Notes that return True will show a 'delete' link. * Parameters * component **self** - A reference to the component that is invoking this function * integer **id** - The id of the note * Return * boolean - Notes with a True return can be deleted by the user, False return can not be deleted.
