--- title: "Vision - Pipe Joint" description: "The Pipe Joint displays a fancy joint component two join two pipe segments together." --- # Vision - Pipe Joint > The Pipe Joint displays a fancy joint component two join two pipe segments together. ![](pipe-joint.png) **Component Palette Icon**: ![](pipe-joint1.png) ## Description The pipe joint displays a joint component to join two pipe segments together. By turning off the cardinal directions, this will display a two-, three-, or four-pipe union. ## Properties | Name | Description | Property Type | Scripting | Category | |--- |--- |--- |--- |--- | | Border | The border surrounding this component. Options are No border, Etched (Lowered), Etched (Raised), Bevel (Lowered), Bevel (Raised), Bevel (Double), and Field Border.**Note**: The border is unaffected by rotation. | Border | .border | Common | | Bottom? | Indicates if the joint has an outlet at the bottom. | boolean | .bottom | Appearance | | Center Fill | The center of the fill gradient. Can be chosen from color wheel, chosen from color palette, or entered as RGB or HSL value. See [Color Selector](appendix/reference-pages/color-selector-reference/color-selector-reference.mdx). | Color | .mainColor | Appearance | | Cursor | The mouse cursor to use when hovering over this component. Options are: Default, Crosshair, Text, Wait, Hand, Move, SW Resize, or SE Resize. | int | .cursorCode | Common | | Edge Fill | The edge of the fill gradient. See [Color Selector](appendix/reference-pages/color-selector-reference/color-selector-reference.mdx). | Color | .secondaryColor | Appearance | | Left? | Indicates if the joint has an outlet at the left. | boolean | .left | Appearance | | Mouseover Text | The text that is displayed in the tooltip which pops up on mouseover of this component. | String | .toolTipText | Common | | Name | The name of this component. See [Color Selector](appendix/reference-pages/color-selector-reference/color-selector-reference.mdx). | String | .name | Common | | Outline Color | The color of the outline border. See [Color Selector](appendix/reference-pages/color-selector-reference/color-selector-reference.mdx). | Color | .outlineColor | Appearance | | Quality | The data quality code for any Tag bindings on this component. | QualityCode | .quality | Data | | Right? | Indicates if the joint has an outlet at the right. | boolean | .right | Appearance | | Styles | Contains the component's styles | Dataset | .styles | Appearance | | Top? | Indicated if that joint has an outlet at the top. | boolean | .top | Appearance | | Visible | If disabled, the component will be hidden. | boolean | .visible | Common | ## Scripting ### Component Functions This component does not have component functions associated with it. ### Extension Functions This component does not have extension functions associated with it. ### Event Handlers Event handlers allow you to run a script based off specific triggers. See the full list of available event handlers on the [Component Events](ignition-modules/vision/scripting-in-vision/component-events/component-events.md) page ## Customizers * [Vision Component Customizers](ignition-modules/vision/working-with-vision-components/vision-component-customizer/vision-component-customizer.md) * [Style Customizer](ignition-modules/vision/working-with-vision-components/vision-component-customizer/vision-component-customizer.md#style-customizer)
