--- title: "Perspective - File Upload Scripting" --- # Perspective - File Upload Scripting > This page details the various scripting, component, and extension functions available for Perspective's [File Upload](appendix\components\perspective-components\perspective-input-palette\perspective-file-upload\perspective-file-upload.md) component. ## Component Events The [Perspective Event Types Reference](appendix/reference-pages/perspective-event-types-reference.md) page describes all the possible component event types for Perspective components. Not all component events support each Perspective component. The [Component Events and Actions](ignition-modules/perspective/working-with-perspective-components/component-events-and-actions.md) page shows how to configure events and actions on a Perspective component. Component scripting is handled separately and can be accessed from the Component menubar or by right clicking on the component. ### onFileReceived Provides a chance to handle file data uploaded to the component. :::note This component event is designed to be used in tandem with a script action. Within the script action, special properties and methods are available on the **event** object, which is passed to the script action as a parameter. ::: #### event.file.name * Object Path * event.file.name * Type * String * Description * The name of the uploaded file. #### event.file.size * Object Path * event.file.size * Type * Integer * Description * The size of the uploaded file in bytes. #### event.file.copyTo(filePath) * Object Path * event.file.copyTo() * Description * Saves the uploaded file at a location accessible to the Gateway. * Parameters * String **filePath** - The path to where the file should be saved on the Gateway. * Return * None #### event.file.getBytes() * Object Path * event.file.getBytes() * Description * Fetches the incoming file data. Suitable for further data processing. * Parameters * None * Return * byteArray - The raw data of the incoming file. #### event.file.getString() * Object Path * event.file.getString() * Description * Fetches the incoming file data and attempts to parse it as a string via UTF-8 (Eight-bit UCS Transformation Format) encoding. Although this defaults to UTF-8, other character sets can be used. For example, getString("UTF_16BE"). * Parameters * None * Return * String - The raw data of the incoming file as a string. ### onUploadsCleared This event is fired when the user has cleared all uploads, but not while uploads are still in progress. :::note This component event is designed to be used in tandem with a script action. Within the script action, special properties and methods are available on the event object, which is passed to the script action as a parameter. ::: #### event.files * Object Path * event.files * Type * List * Description * A list containing a number of PyJsonObjectAdapters, where each adapter contains a `name` (string) and `size` in bytes (integer bytes) ![](onFilesClearExample.png) ```python title="Event.Files Example" # Prints a message per file showing its name and file size messageTemplate = "Cleared %s with a size of %d bytes" for file in event.files: system.perspective.print(messageTemplate % (file.name, file.size)) ``` ```python title="Accessing File Name Individually" # Alternatively you can access individual items: messageTemplate = "The name of the first file cleared is: %s" system.perspective.print(messageTemplate % event.files[0].name) ``` ## Component Functions ### .clearUploads() * Description * Resets the File Upload component to its default state :::note clearUploads() does not remove or delete uploaded files from the Gateway. Clearing uploads does not undo any actions triggered by the onFileReceived() Component Event. ::: * Parameters * None * Return * Nothing ## Extension Functions This component does not have extension functions associated with it.
