--- title: "Perspective - Coordinate Container Scripting" --- # Perspective - Coordinate Container Scripting > This page details the various scripting, component, and extension functions available for [Perspective's Coordinate Container](perspective-coordinate-container.md) component. ## Component Events The [Perspective Event Types Reference](appendix/reference-pages/perspective-event-types-reference.md) page describes all the possible component event types for Perspective components. Not all component events support each Perspective component. The [Component Events and Actions](ignition-modules/perspective/working-with-perspective-components/component-events-and-actions.md) page shows how to configure events and actions on a Perspective component. Component scripting is handled separately and can be accessed from the Component menubar or by right clicking on the component. ### onPipeClicked This event will trigger when a pipe in this container is clicked. :::note This component event is designed to be used in tandem with a script runAction. Within the script action, special properties and methods are available on the **event** object, which is passed to the script action as a parameter. ::: #### event.event * Object Path * event.event * Type * Dictionary * Description * The event object generated from the mouse click. #### event.pipeIndex * Object Path * event.pipeIndex * Type * Integer or float * Description * The array index of the pipe within props.pipes that was clicked. #### event.pipeName * Object Path * event.pipeName * Type * String * Description * The name of the pipe that was clicked. ## Component Functions ### .getChildren() * Description * Returns an ArrayList, which contains references to all components inside of the container. * Parameters * None * Return * Array List - An ArrayList of components in the container. The resulting ArrayList can be iterated over via a for-loop. ## Extension Functions This component does not have extension functions associated with it.
