--- title: "XY Chart Example - Heat Map" --- # XY Chart Example - Heat Map > This example demonstrates how to configure a Heatmap, where the value of each cross axis is represented as a color along a gradient. This style of chart is largely accomplished by setting the series "render" property to "column", and enabling "heatRules". ![](2020-05-28.png) The data used in this example is shown in the code block below: The x-axis is set to the "year" key, while the y-axis is set to the "fruit" key. The "dataField" property under "heatRules" is set to the "count" key. * year - the x-axis * fruit - the y-axis * count - determines the color used in the block. ``` [ { "year": 2015, "fruit": "apple", "count": 20 }, { "year": 2015, "fruit": "orange", "count": 400 }, { "year": 2015, "fruit": "banana", "count": 150 }, { "year": 2016, "fruit": "apple", "count": 200 }, { "year": 2016, "fruit": "orange", "count": 300 }, { "year": 2016, "fruit": "banana", "count": 400 }, { "year": 2017, "fruit": "apple", "count": 200 }, { "year": 2017, "fruit": "orange", "count": 400 }, { "year": 2017, "fruit": "banana", "count": 30 } ] ``` ### Notable Property Configurations The example requires both an X axis and a Y axis in addition to some series properties. |PROPS Path| Property Description|Value| |--|--|--| |`xAxes.0.render` |Makes the chart group values in the X Axis, and provides equal padding between each category. Partially responsible for rendering boxes on the chart. | category| |`yAxes.0.render` |Makes the chart group values in the Y Axis, and provides equal padding between each category. Partially responsible for rendering boxes on the chart. | category| |`series.0.render`| When combined with "category" renders for the X and Y axes, allows the categories boxes to be rendered on the chart. | column| |`series.0.column.appearance.heatRules.enabled`| Makes the chart change the color on each category based on dataField key ("count", in our example), applying the min and max colors. | true| |`series.0.column.appearance.heatRules.max`| The property represents which color to use for higher values. |#26E3B1| |`series.0.column.appearance.heatRules.min`| The property represents which color to use for lower values. |#E5DBDB (pick a color you want to represent low colors)| |`series.0.column.appearance.heatRules.dataField`| Determines which key in the underlying data should be used to determine the vibrancy of each block. | count| ### Example Configuration The JSON string below can be used to replicate the heatmap example. Simply copy the contents of the code block below and paste it into a container in your Designer. ``` [ { "type": "ia.chart.xy", "version": 0, "props": { "legend": { "enabled": false }, "xAxes": [ { "name": "year", "label": { "enabled": true, "text": "year", "color": "" }, "visible": true, "tooltip": { "enabled": true, "text": "", "cornerRadius": 3, "pointerLength": 4, "background": { "color": "", "opacity": 1 } }, "inversed": false, "render": "category", "category": { "break": { "enabled": false, "startCategory": "", "endCategory": "", "size": 0.05 } }, "date": { "baseInterval": { "enabled": false, "timeUnit": "hour", "count": 1, "skipEmptyPeriods": false }, "range": { "max": "", "min": "", "useStrict": false }, "break": { "enabled": false, "startDate": "", "endDate": "", "size": 0.05 }, "inputFormat": "yyyy-MM-dd kk:mm:ss", "format": "M/d" }, "value": { "range": { "max": "", "min": "", "useStrict": false }, "logarithmic": false, "break": { "enabled": false, "startValue": 0, "endValue": 100, "size": 0.05 }, "format": "#,###.##" }, "appearance": { "opposite": true, "inside": false, "labels": { "color": "", "opacity": 1, "rotation": 0, "verticalCenter": "middle", "horizontalCenter": "middle" }, "grid": { "color": "", "opacity": 1, "dashArray": "", "minDistance": 60, "position": 0.5 }, "font": { "size": "", "weight": 500 } } } ], "yAxes": [ { "name": "fruit", "label": { "enabled": true, "text": "fruit", "color": "" }, "visible": true, "tooltip": { "enabled": true, "text": "", "cornerRadius": 3, "pointerLength": 4, "background": { "color": "", "opacity": 1 } }, "inversed": false, "render": "category", "category": { "break": { "enabled": false, "startCategory": "", "endCategory": "", "size": 0.05 } }, "date": { "baseInterval": { "enabled": false, "timeUnit": "hour", "count": 1, "skipEmptyPeriods": false }, "range": { "max": "", "min": "", "useStrict": false }, "break": { "enabled": false, "startDate": "", "endDate": "", "size": 0.05 }, "inputFormat": "yyyy-MM-dd kk:mm:ss", "format": "M/d/yyyy HH:mm:ss" }, "value": { "range": { "max": "", "min": "", "useStrict": false }, "logarithmic": false, "break": { "enabled": false, "startValue": 0, "endValue": 100, "size": 0.05 }, "format": "#,###.##" }, "appearance": { "opposite": false, "inside": false, "labels": { "color": "", "opacity": 1, "rotation": 0, "verticalCenter": "middle", "horizontalCenter": "middle" }, "grid": { "color": "", "opacity": 1, "dashArray": "", "minDistance": null, "position": 0.5 }, "font": { "size": "", "weight": 500 } } } ], "series": [ { "name": "count", "label": { "text": "Process Temp" }, "visible": true, "hiddenInLegend": false, "defaultState": { "visible": true }, "data": { "source": "data", "x": "year", "y": "fruit" }, "xAxis": "year", "yAxis": "fruit", "zIndex": 0, "tooltip": { "enabled": true, "text": "{name}: [bold]{valueY}[/]", "cornerRadius": 3, "pointerLength": 4, "background": { "color": "", "opacity": 1 } }, "render": "column", "candlestick": { "open": { "x": "", "y": "" }, "high": { "x": "", "y": "" }, "low": { "x": "", "y": "" }, "appearance": { "fill": { "color": "", "opacity": 1 }, "stroke": { "color": "", "opacity": 1, "width": 1 }, "stacked": false, "deriveFieldsFromData": { "fill": { "color": "", "opacity": "" }, "stroke": { "color": "", "opacity": "", "width": "" } }, "heatRules": { "enabled": false, "max": "", "min": "", "dataField": "" } } }, "column": { "open": { "x": "", "y": "" }, "appearance": { "fill": { "color": "", "opacity": 1 }, "stroke": { "color": "", "opacity": 1, "width": 1 }, "stacked": false, "width": null, "height": null, "deriveFieldsFromData": { "fill": { "color": "", "opacity": "" }, "stroke": { "color": "", "opacity": "", "width": "" } }, "heatRules": { "enabled": true, "max": "#26E3B1", "min": "#E5DBDB", "dataField": "count" } } }, "line": { "open": { "x": "", "y": "" }, "appearance": { "connect": true, "tensionX": 1, "tensionY": 1, "minDistance": 0.5, "stroke": { "width": 3, "opacity": 1, "color": "", "dashArray": "" }, "fill": { "opacity": 0, "color": "" }, "bullets": [ { "enabled": false, "render": "circle", "label": { "text": "{value}", "position": { "dx": 0, "dy": 0 }, "truncate": true, "hideOversized": true }, "fill": { "color": "", "opacity": 1 }, "stroke": { "color": "", "opacity": 1, "width": 1 }, "rotation": 0, "radius": 5, "tooltip": { "enabled": true, "text": "{name}: [bold]{valueY}[/]", "cornerRadius": 3, "pointerLength": 4, "getFillFromObject": true, "background": { "color": "", "opacity": 1 } }, "deriveFieldsFromData": { "fill": { "color": "", "opacity": "" }, "stroke": { "color": "", "opacity": "", "width": "" }, "rotation": "" }, "heatRules": { "enabled": false, "max": 100, "min": 2, "dataField": "" }, "width": 10, "height": 10 } ] } }, "stepLine": { "open": { "x": "", "y": "" }, "appearance": { "connect": true, "tensionX": 1, "tensionY": 1, "minDistance": 0.5, "stroke": { "width": 3, "opacity": 1, "color": "", "dashArray": "" }, "fill": { "opacity": 0, "color": "" }, "bullets": [ { "enabled": true, "render": "circle", "label": { "text": "{value}", "position": { "dx": 0, "dy": 0 }, "truncate": true, "hideOversized": true }, "fill": { "color": "", "opacity": 1 }, "stroke": { "color": "", "opacity": 1, "width": 1 }, "rotation": 0, "radius": 5, "tooltip": { "enabled": true, "text": "{name}: [bold]{valueY}[/]", "cornerRadius": 3, "pointerLength": 4, "getFillFromObject": true, "background": { "color": "", "opacity": 1 } }, "deriveFieldsFromData": { "fill": { "color": "", "opacity": "" }, "stroke": { "color": "", "opacity": "", "width": "" }, "rotation": "" }, "heatRules": { "enabled": false, "max": 100, "min": 2, "dataField": "" }, "width": 10, "height": 10 } ] } } } ], "style": { "marginRight": "100px", "paddingRight": "100px" }, "dataSources": { "data": [ { "year": 2015, "fruit": "apple", "count": 20 }, { "year": 2015, "fruit": "orange", "count": 400 }, { "year": 2015, "fruit": "banana", "count": 150 }, { "year": 2016, "fruit": "apple", "count": 200 }, { "year": 2016, "fruit": "orange", "count": 300 }, { "year": 2016, "fruit": "banana", "count": 400 }, { "year": 2017, "fruit": "apple", "count": 200 }, { "year": 2017, "fruit": "orange", "count": 400 }, { "year": 2017, "fruit": "banana", "count": 30 } ] } }, "meta": { "name": "XYChart" }, "position": { "x": 130, "y": 103, "width": 435, "height": 375 }, "custom": {} } ] ```
