--- title: "User Attribute Mapping" --- # User Attribute Mapping > The User Attribute Mapping page allows you to map information in the Identity Providers (IdP) response document to easily understandable properties. These properties are then made available as [Session Properties](ignition-modules\perspective\perspective-sessions\session-properties.md) in the Perspective Session. To work, this requires that the Gateway already has a valid IdP configuration which returns a response document when attempting to login. ## Configuring a User Attribute Mapping 1. From the Gateway Webpage **Config** tab, click on **Security > Identity Providers**. 2. Select the **Identity Provider** and click on **User Attribute Mapping** under the **More** button. ![](idp-user-att-mapping.png) 3. The Name, Description, and Provider Type are not editable here, but are listed on the page to make clear which IdP the User Attribute Mapping is being configured on. ![](name-desc-type.png) 4. Under the **User Attributes** section of properties, you'll find settings for each of the mappable user attributes. ![](user-attributes.png) 5. If you make changes to any of the mappings, be sure to click **Save** when finished. ## User Attribute Mapping Property Reference Table Mappings can be configured on several user attributes. |Attribute |Description |Data Type | |--|--|--| |ID |The Type of mapping to apply for user IDs. |String | |Username |The Type of mapping to apply for usernames. |String | |First Name |The type of mapping to apply for first names. |String | |Last Name |The type of mapping to apply for last names. |String | |Email |The type of mapping to apply for email addresses. |String | |Roles |The type of mapping to apply for user roles. **Note:** While using an Expression type attribute mapping, you can use a [runScript](appendix\expression-functions\advanced\runScript.md) call to create a list of roles through scripting. However the script must return an ArrayList, as opposed to Jython collection types:
import java.util.ArrayList as ArrayListroles = ArrayList()roles.add("Operator")
|Java ArrayList of Strings | Each attribute mapping has similar properties, which are listed below |Property Name |Description | |--|--| |Type | The Type of mapping to apply for the attribute. Options are [direct](#direct-mapping) or [expression](#expression-mapping). | |Source |The name of the attribute source. In cases where the identity provider has several [Attribute Sources](#attribute-sources), this property allows you to specify which source the mapping should use. (for **direct** type only) | |Path |Path to the attribute map based on the selected source. Each node in the path is delimited by a slash character ( "/" ). (for **direct** type only) | |Expression |The source code for the expression used to map the targeted user attribute. See the [Security Level Rules](platform\security\identity-provider-authentication-strategy\security-level-rules\security-level-rules.md#special-object-reference). (for **expression** type only) | ## Direct Mapping Direct mappings require that you enter in the path to an attribute in the response document for the given property. Values in the Identity Provider’s response document are dereferenced using the configured paths and are copied to the respective user properties in Ignition. The Source dropdown allows a particular mapping to target a specific object in the response document. The Path property then determines what object inside of source should be. In the image below, the ID of the user, as represented on the Ignition Gateway, will be determined by the **sub** attribute, located in the **ID Token Claims** source in the response document. ![](user-att-id.png) ### Attribute Sources Each Identity Provider has a different list of possible attribute sources. Below are several tables that list each possible source, as well as the expression path name for the source (used by `{attribute-source:X:Y}` and `{multi-attribute-source:X:Y}` expression paths. See [Security Level Rules](platform\security\identity-provider-authentication-strategy\security-level-rules\security-level-rules.md).) |IdP Type |Attribute Source(s) | |--|--| |Ignition |ID Token Claims (default) | |Ignition |Token Endpoint Response | |OIDC |ID Token Claims (default) | |OIDC |Token Endpoint Response | |OIDC |User Info Claims | |SAML |Authentication Response | For Ignition and OIDC IdPs, the correct source to use will vary with the referenced attribute, and is included in the response document on the [Test Login](platform\security\identity-provider-authentication-strategy\test-login-and-logout\test-login-and-logout.md) page. :::note The user info claims attribute source is present only when the user info URL is configured and Ignition receives a valid user info response from the IdP. ::: ## Expression Mapping The Expression type allows you to use the [expression language](platform\expression-language-and-syntax\expression-language-and-syntax.md) to derive the mapping from contextual data, such as the IdP response document or Tags. To assist with parsing the response document in an expression, there are several built-in objects. ![](expression-mapping.png) ## Built-in Expression Objects In IdP contexts, it is possible to reference IdP response document elements using a three-part format: ``` {::} ``` In this format, `""` is the attribute type we're attempting to reference, `""` is the name of the top-level attribute source, and `""` is a path to the property inside the attribute source. Here, we'll discuss the possible values for each part of this expression, and when they should be used. ### Attribute Type |Type |Expression Value |Description | |--|--|--| |Single-Valued Object |`attribute-source` |Provides the ability to reference an attribute (such as the username) returned from an IdP attribute source where the attribute's value is expected to be a single atomic value, usually a string. | |Multi-Valued Object |`multi-attribute-source` |Provides the ability to reference an attribute (such as the user's roles) returned from an IdP attribute source where the attribute's value is expected to be a collection of single atomic values, usually a collection of strings. | ### Attribute Source Possible values for the attribute source will vary by IdP type: |IdP Type |Attribute Source(s) |Expression Path Name | |--|--|--| |Ignition |ID Token Claims (default) |`idTokenClaims` | |Ignition |Token Endpoint Response |`tokenEndpointResponse` | |OIDC |ID Token Claims (default) |`idTokenClaims` | |OIDC |Token Endpoint Response |`tokenEndpointResponse` | |OIDC |User Info Claims |`userInfo` | |SAML |Authentication Response |`authnResponse` | For Ignition and OIDC IdPs, the correct source to use will vary with the referenced attribute, and is included in the response document on the [Test Login](platform\security\identity-provider-authentication-strategy\test-login-and-logout\test-login-and-logout.md) page. Prior to Ignition 8.1.5, the expression path for SAML Authentication Response did not have an explicit name, so the attribute-source expression path would simply default to Authentication Response in all cases. As of 8.1.5, authnResponse must be explicitly stated when attempting to access the Authentication Response source with expression paths. See [Expression Mapping](#expression-mapping). ### Attribute Path The final element in an attribute reference is a path to the attribute within the attribute source. Here, the [Test Login](platform\security\identity-provider-authentication-strategy\test-login-and-logout\test-login-and-logout.md) page is helpful for accessing the attribute source's structure in the response document. If the attribute source is a JSON document (as is the case with Ignition and OIDC IdPs), then a JSON Path may be used to reference the target attribute. If the attribute source is an XML document (as is the case with SAML IdPs), then an [XPath 1.0 expression](https://www.w3schools.com/xml/xpath_syntax.asp) may be used to reference the target attribute. See the [Multi-Valued Object Example](#multi-valued-object-example) further down. ### Single-Valued Object Example This example makes use of the Single-Valued Object on an JSON response document from an OpenID Connect IdP. The document used by this example is listed in the code block below.
Sample OIDC Response Document ```json { "idTokenClaims": { "sub": "00u4zl66kjWSxpKyH357", "name": "Paul Person", "email": "person@company.com", "ver": 1, "iss": "https://573779.okta.com", "aud": "0oa2uqi4odPcNHRpS357", "iat": 1617831866, "exp": 1617835466, "jti": "ID.itbv0TrKsyxqJpEsqwkVHaVa07xBD_haRQMnGUQ5tz4", "amr": [ "pwd" ], "idp": "00ob8o86nJ2kN48V4356", "nonce": "a2Zq9QA1xL7t_apS58YIPaegbGD9w6FN60qSgP0i7fg", "preferred_username": "person@company.com", "auth_time": 1617831865, "at_hash": "TEbuSUf8aMhWGYDuHsC0jQ" }, "tokenEndpointResponse": { "token_type": "Bearer", "expires_in": 3600, "access_token": "eyJraWQiOiJCVlowd3JweUdiRnB5cG5EQ05HbUpnMnhtbW5sc0h3TlBRdVp3MjQxSjdrIiwiYWxnIjoiUlMyNTYifQ.eyJ2ZXIiOjEsImp0aSI6IkFULmhmaEVRLUFiZzIyVU1Bb3NWNm9wWld1NHFGWmIzZUdLR25VVUNhX1lWWWciLCJpc3MiOiJodHRwczovL2Rldi01NzM3Nzkub2t0YS5jb20iLCJhdWQiOiJodHRwczovL2Rldi01NzM3Nzkub2t0YS5jb20iLCJzdWIiOiJwc2NvdHRAaW5kdWN0aXZlYXV0b21hdGlvbi5jb20iLCJpYXQiOjE2MTc4MzE4NjYsImV4cCI6MTYxNzgzNTQ2NiwiY2lkIjoiMG9hMnVxaTRvZFBjTkhScFMzNTciLCJ1aWQiOiIwMHU0emw2NmtqV1N4cEt5SDM1NyIsInNjcCI6WyJvcGVuaWQiLCJlbWFpbCIsInByb2ZpbGUiXX0.GR3JoTmbNtD7FDV59cuiE3wXsNJARN_zz5pmtnhLr19BGgiR7KJonYXBo7E_KPJ82RAEKsGRKFLzSDIzaB2QUCPyzJSsNg2LKvht5yoQoguoY6HqgeU73UkF6gbEhE3c_WfW1reewN8eazIOnvYJQhmVZYrhlF04XYOcB8o_1raNku3yUw76MDyAlWpaXuYQ2b9UYir3CLlb7AwpYTHdRHAk7zdFv713m4aR5IgVt0Pch8pFarX4k3o6Sg4ZghLW-4eioSzs0CrVLk3j09vQIEKn0jdlKqY0i9_9HBiEGUrVOXuiJ587ocRTjvxeNCpr_B7DBczBbtTkOFNzw3xRhw", "scope": "openid email profile", "id_token": "eyJraWQiOiJUNEhmZDQ0LXVVQ09sMGJpTl9fWnprQkJYWVdSSXlQYXBIZi1QeFRFTHYwIiwiYWxnIjoiUlMyNTYifQ.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.b5wi6CH0p1OigL6aaamZu3aVbOHRgiKdHFKqEgU0PLfbTILGtabhLktic843XaBTiQm8s3oXz153P3rdsUP4VPj1jXF8C221iEjP-55PyBX2kQ-ggyqXVrWlywmOWFNn4kSjViuzMIt2gXeW8yW-OBtxBTZr7QPDF6XKwZk6V183K0hT3ZbrzHcqZ0juIEkxrrfDU8N8Fo8bO94A2rGPp0mfSPttkrxxZBJ3bO6oY5e7NtcBnt4IsbSZfvI3_1KUoQt0SylljsescEZGxRJCfNdE3dJyOaQZuBKLN8ouxibD9Jdmn9_raeLGKOsxNHK0pNMRbptJ9UD4VemyezQvzA" }, "userInfo": { "sub": "00u4zl66kjWSxpKyH357", "name": "Paul Person", "locale": "en-US", "email": "person@company.com", "preferred_username": "person@company.com", "given_name": "Paul", "family_name": "Person", "zoneinfo": "America/Los_Angeles", "updated_at": 1596495564, "email_verified": true } } ```
If, for example, we wanted to configure a mapping on the First Name, which would allow us to retrieve the name of the user provided by the response document. The **given_name** under **userInfo** appears to have the value we're looking for. We can use the attribute-source object to directly reference the node. ``` {attribute-source:userInfo:given_name} ``` This is equivalent to using a direct mapping type with Source set to "ID Token Claims" and Path set to "name". However, since we're using the expression language, we have access to more tools, which is useful in cases where the attribute value we're looking for isn't as readily accessible. For example, say the response document did not contain a node that represented just the users first name. However, it does contain a name under idTokenClaims (line 4) to that has the user's full name. We could access the full name, and then use the expression language's [split](appendix\expression-functions\string\split.md) function to split the first and last names. ``` split({attribute-source:idTokenClaims:name}, ' ')[0,0] ``` ### Multi-Valued Object Example This example makes use of the Multi-Valued Object on an XML response document from a SAML IdP. Here we can use an [XPath expression](https://www.w3schools.com/xml/xpath_syntax.asp) to examine the document and reference a specific node. We'll configure an expression type mapping that will retrieve attribute values that we want mapped to a user's Roles. Below we see the results of a [test login](platform\security\identity-provider-authentication-strategy\test-login-and-logout\test-login-and-logout.md). Our user does not appear to have any roles mapped. ![](test-results.png) If we click on the **IdP Response Data** tab, we see the results listed in the code block below.
Sample SAML Response Document ```xml http://www.okta.com/exkj0b0vtttYvPzH10h7 UYW4pdcsWK19aRbSl3NlgRc+RZ1jIyCK6hsXnSu7VYs= http://www.okta.com/exkj0b0vtttYvPzH10h7 xNlFDTmRTPXYqSLpruOZoPSq2Lz6q1rPrGiROR6MXdM= person@company.com http://localhost:8088 urn:oasis:names:tc:SAML:2.0:ac:classes:PasswordProtectedTransport Paul Scott person@company.com Operator Supervisor ```
In the example document, lines 68 and 69 contain saml2:AttribueValue elements, which contain the roles for our user. Starting from the roles, we can work our way back towards the top of the document, but making the following observations. * We see both elements are under a `saml2:Attribute` element (line 67). * The `saml2:Attribute` element is under a `saml2:AttributeStatement` element (line 57). * The `saml2:AttribueStatement` element is under a `saml2:Assertion` element (line 23). * Finally, the `saml2:Assertion` element is under the `saml2p:Response element`, which seems to be the root for the entire path (line 2). Thus, we're looking for all text values of all saml2:AttributeValue elements that are under a specific saml2:Attribute element. We see that the saml2SAttribute element we're looking for also has name attribute set to "Role", which we can use to help focus our path. Based on our observations, the path looks like the following: Note that we start at the root of the saml2p:Reponse element (on the left), and build the rest of the path in reverse order of our observations. We specified that the saml2:Attribute must contain an attribute by the name of "Name", with a value of "Role", with which filters out the other saml2:Attribute elements in the document (such as the elements with FirstName and LastName). In addition, we ended the path with text(), which access the text values of the nodes. ``` /saml2p:Response/saml2:Assertion/saml2:AttributeStatement/saml2:Attribute[@Name="Role"]/saml2:AttributeValue/text() ``` #### Writing the Path Now that we know what our path looks like, we can write an expression. We'll type the following into the "Expression" field for the Roles setting: ``` {multi-attribute-source:authnResponse:/saml2p:Response/saml2:Assertion/saml2:AttributeStatement/saml2:Attribute[@Name="Role"]/saml2:AttributeValue/text()} ``` ![](roles.png) If we then **Save**, we can attempt a [test login](platform\security\identity-provider-authentication-strategy\test-login-and-logout\test-login-and-logout.md), and check the mapped user attributes, where we see our roles from the response document now appear mapped to our user. ![](name-value.png) ### Tag Path Example In addition, Tag values can be referenced by mappings. Note that the values are only checked when the user logs in. So if the value of any tags used in a mapping change after the user logs in, the result of the mapping won't retroactively change. ``` {[default]A_Folder/A_Tag.value} ``` In the example above, the expression would attempt to return the value of the Tag at path "A_Folder/A_Tag", in the Tag Provider named "default".
