--- title: "Exporting and Importing a CSV" --- # Exporting and Importing a CSV > A CSV (comma separated values) file, is one of the most simple structured formats used for exporting and importing datasets. It is a convenient and flexible way to edit and share data across applications. Ignition has a built-in function to convert a dataset to CSV data called [system.dataset.toCSV](appendix\scripting-functions\system-dataset\system-dataset-toCSV.md). You can even convert the contents of a CSV to a script and move it to an Ignition component, such as a Power Table. This section contains examples for exporting and importing data to a CSV as well as converting the contents of a CSV to a script. :::note The examples on this page make use of Vision components, and run in the Vision Client scope. ::: ## Exporting Data to a CSV You can export a dataset from a query or table to a CSV file. 1. Identify the dataset that you want to export to a CSV file. In this case, we can generate some data on a Power Table and export that data. Drag a **Power Table** component on to your window and toggle its **TestData** property to generate some data. ![](testdata.png) 2. Drag a **Button** component on the window, and double click on the Button to open the **Component Scripting** window. 3. Next, let's add our script on the Button component's actionPerformed event. Select the **actionPerformed** event, and click on the **Script Editor** tab. 4. Copy the contents from one of the examples below, and paste the contents to the **Script Editor**. Notice the [system.dataset.toCSV](appendix\scripting-functions\system-dataset\system-dataset-toCSV.md) scripting function is used in the first example to export the dataset to a CSV file: ```python title="Python - Hard Coded Filepath" # Create a variable that references our Power Table. You could modify this part # of the example to point to a different component in the window. component = event.source.parent.getComponent('Power Table') # Use system.dataset.toCSV to turn the dataset into a CSV string csv = system.dataset.toCSV(component.data) # Write to local file system. Note the "r" character right before the directory path. # This denotes a raw string literal, meaning we ignore escape sequences (like the "/") system.file.writeFile(r"C:\myExports\myExport.csv", csv) ``` ![](actionperformed.png) 5. Instead of hardcoding the path as we did in the above example, we could ask the user to select a directory on the local system with [system.file.saveFile](appendix\scripting-functions\system-file\system-file-saveFile.md): ```python title="Python - User Selected Directory" # Create a variable that references our Power Table. You could modify this part # of the example to point to a different component in the window. component = event.source.parent.getComponent('Power Table') # Use system.dataset.toCSV to turn the dataset into a CSV string. csv = system.dataset.toCSV(component.data) # Use system.file.saveFile to have the user find a directory to write to. filePath = system.file.saveFile("myExport.csv", "csv", "Comma Separated Values") # We can check the value of filePath to make sure the user picked a path before # attempting to write. if filePath: system.file.writeFile(filePath, csv) ``` To test your scripts, put the Designer in **Preview Mode**, and press the **Button**. Open your **myExport.csv** file and check your data. ![](myexport.png) ## Importing Data from a CSV There are several ways to import data from a CSV file. First, we could use [system.file.readFileAsString](appendix\scripting-functions\system-file\system-file-readFileAsString.md) to read the entire file as a string. Note, that this will read the file as is, meaning `\n` can be used to denote new lines. ```python title="Python - Using system.file.readFileAsString()" # Ask the user to find the CSV in the local file system. path = system.file.openFile("csv") # Use readFileAsString to read the contents of the file as a string. # This string will be the parameter we pass to fromCSV below stringData = system.file.readFileAsString(path) # Split stringData into a List of strings, delimited by the new line character stringData = stringData.split("\n") # Iterate through the list, and do something with each line for i in range(len(stringData)): # We're printing the row here, but you could do something more useful with the data. print stringData[i] ``` Alternatively, Python's CSV Library could be use to read in the contents of a CSV. In some cases, this is the easier approach, as the reader object is ready to be iterated over. Note, that this approach does read in each row as a List of strings: ```python title="Python - Using csv.reader()" # Import Python's built-in csv library import csv # Ask the user to find the CSV in the local file system. path = system.file.openFile("csv") # Create a reader object that will iterate over the lines of a CSV. # We're using Python's built-in open() function to open the file. file = open(path) csvData = csv.reader(file) # Iterate through the reader object, and do something with each line for row in csvData: # We're printing the row here, but you could do something more useful with the data. print row # Close the file once we're done with it file.close() ``` ## Converting the Data into a Dataset Once you've read in the contents of a CSV into a script, you may wish to move it elsewhere. It is not uncommon to move the data to a **Power Table**, or other components on the screen. The main difficulty with this is converting the CSV data into a dataset so that it fits into the **Power Table** component's **Data** property. We have a couple of approaches listed below. ### Calling the system.dataset.fromCSV Function The [system.dataset.fromCSV](appendix\scripting-functions\system-dataset\system-dataset-fromCSV.md) function can take a string and convert it to a dataset. Note, that the function expects a very specific format: ```python title="CSV File Content" #NAMES Col 1,Col 2,Col 3 #TYPES I,str,D #ROWS,6 44,Test Row 2,1.8713151369491254 86,Test Row 3,97.4913421614675 0,Test Row 8,20.39722542161364 25,Test Row 4,20.39722542444222 33,Test Row 5,20.39722542232323 62,Test Row 6,20.39722542111999 ``` #### Example 1. Create a Text file on your local system named "**example.csv**." 2. Open the Text file, copy the contents of the "**CSV file Content**" box above, and paste the contents to the file. Save the changes to the **example.csv** file. ![](example-notepad.png) 3. Let's move the contents of a CSV file to a Power Table. Add a **Power Table** and a **Button** component to your window. Double click on the **Button** component, and paste the following code into the **Script Editor** of the **actionPerformed** event: ```python title="Python - Using system.dataset.fromCSV()" # Ask the user to find the CSV in the local file system. path = system.file.openFile("csv") # Use readFileAsString to read the contents of the file as a string. stringData = system.file.readFileAsString(path) # Convert the string into a dataset data = system.dataset.fromCSV(stringData) # Pass the dataset to the data property on the Power Table. event.source.parent.getComponent('Power Table').data = data ``` ![](fromcsv.png) 4. To execute your script, put the Designer into **Preview Mode**, and press the **Button**. A window will open for you for you to navigate and choose your CSV file, then click Open. ![](export-import.png) Your data will be displayed in the Power Table as shown below. ![](power-table.png) ### Calling the csv.reader Function As mentioned, system.dataset.fromCSV() requires a specific format, which may not match the format of your file. In this case, we can use Python's CSV Library to parse the file and convert it to a dataset. ```python title="CSV File Content" Col 1,Col 2,Col 3 44,Test Row 2,1.8713151369491254 86,Test Row 3,97.4913421614675 0,Test Row 8,20.39722542161364 25,Test Row 4,20.39722542444222 33,Test Row 5,20.39722542232323 62,Test Row 6,20.39722542111999 ``` Here is the code to import the above CSV data. ```python title="Python - Using Python's csv Library" # Import Python's built-in csv library. import csv # Ask the user to find the CSV in the local file system. path = system.file.openFile("csv") # Create a reader object that will iterate over the lines of a CSV. # We're using Python's built-in open() function to open the file. file = open(path) csvData = csv.reader(file) # Create a List of strings to use as a header for the dataset. Note that the number # of headers must match the number of columns in the CSV, otherwise an error will occur. # The simplest approach would be to use next() to read the first line in the file, and # store that at the header. header = csvData.next() # Create a dataset with the header and the rest of our CSV. dataset = system.dataset.toDataSet(header ,list(csvData)) # Store it into the table. event.source.parent.getComponent('Power Table').data = dataset # Close the file file.close() ```
