--- title: "Audit Log Displays" --- # Audit Log Displays >
This page documents several ways to view results from the Audit Log System. For more information on how the Audit Log works, see the [Audit Log and Profiles](platform/audit-log-and-profiles/audit-log-and-profiles.md) page. ## Access the Audit Log with Table Functions ### Vision In Vision, you can easily access and display the audit log using table functions. 1. Ensure you have an [Audit Log set up and attached to a project](platform/audit-log-and-profiles/audit-log-and-profiles.md). 2. Open the Designer and navigate to your Vision project. 3. Drag a **Table** component onto a window. 4. In the **Property Editor**, click the binding icon for the table's **Data** property. The Property Binding window will appear. 5. Select the **Functions** binding type and choose **Audit Log** from the **Binding Function** drop-down menu. 6. Configure the binding options: - **Audit Profile Name**: Select your Audit Profile. - **Start Date**: Enter the appropriate start date. - **End Date**: Enter the appropriate end date. - **Polling Mode**: Select **Relative**. ![](img1-updated.png) 7. Click **OK** to apply the binding. The Table will populate with the audit log data based on the selected parameters. 8. Use the [Table Customizer](appendix/components/vision-components/tables/table/table-customizer.md) to configure the Table's appearance by reorganizing and hiding columns, making columns sortable, and assigning meaningful headers. ![](img2.png) ### Perspective Currently, Perspective does not have an automatic way to query the audit log. Instead, you can use a Named Query or the `system.util.queryAuditLog` function to display audit log data. #### Using a Named Query To display audit log data using a Named Query: 1. Create the Named Query: 1. In the Designer, navigate to **Project** > **Named Queries**. 2. Create a new query named `AuditLogQuery`. 3. Select the Database Connection that contains the audit log data and enter the following SQL query: ```sql SELECT * FROM audit_events WHERE event_timestamp BETWEEN :startDate AND :endDate ORDER BY event_timestamp DESC ``` 4. Add parameters `startDate` and `endDate` with the Data Type **DateTime**. ![](perspective-img4.png) 2. Bind the Named Query to a Table: 1. In a Perspective View, drag a **Table** component onto the canvas. 2. Select the Table component and go to the **Props** section. 3. Bind the **data** property to the Named Query you created. 4. Configure the parameters `startDate` and `endDate` to specify the date range for the query. ![](perspective-img3.png) 3. Customize the Table columns to display the data correctly. This may include formatting dates and adjusting column headers. 4. Save your changes and launch the Perspective session. The Table component will now display the audit log data for the specified date range. ![](perspective-img5.png) For more details, see [Named Queries](platform\sql-in-ignition\named-queries\named-queries.md). #### Using `system.util.queryAuditLog` To display audit log data using the `system.util.queryAuditLog` function: 1. In the Designer, drag a **Table** component onto a new View. Name it **auditLogTable** for the script example below to work. 2. Right-click on the root container of the View and select **Configure Events...**. 3. In the editor, select the appropriate event (e.g., **onStartup**). 4. Click the ![](addIcon.png) and select **Script**. ```python title="Example Script" # Define the start date and end date for the query today = system.date.now() startDate = system.date.addDays(today, -7) # Example: last 7 days endDate = today # Query the audit log using the specified date range results = system.util.queryAuditLog("AuditLog", startDate, endDate) # Set the data property of the Table component with the results self.getChild("auditLogTable").props.data = results ``` 3. The Table component can take the raw output of the `system.util.queryAuditLog` function. However, you will need to configure the columns in the Table's **props** to display the data correctly. For instance, the date will show as seconds since the Unix epoch by default, so you may need to format it appropriately. 4. Save your changes in the Designer. 5. Open the Perspective session in a browser and you'll see the **auditLogTable** automatically populates with the audit log data on startup. ![](perspective-img1.png) For more details, see [system.util.queryAuditLog](appendix/scripting-functions/system-util/system-util-queryAuditLog.md). ## Access the Audit Log Using the Database Query Browser The Database Query Browser allows you to search your database tables to view audit information. 1. In the Designer, go to the **Tools** menu and select **Database Query Browser**. The Database Query Browser window will open. 2. On the right side under **Schema**, double-click the **audit_events** table, then click **Execute**. The data from the audit_events table will appear in the Resultset tab. ![](img3-updated.png) For more details, see [Database Query Browser](platform/designer/designer-tools/database-query-browser/database-query-browser.md). ## Access the Audit Log on the Gateway Ignition provides a simple interface to view Audit Logs directly on the Gateway: 1. On the Gateway webpage, navigate to the **Config** section and scroll down to **Security > Auditing**. 2. The Audit Profile page will display. Select the Audit Profile where your information is stored and click **More > view log**. ![](img4.png) 3. Enter specific parameter text if you're looking for something particular, otherwise, enter a **Start Date** and **End Date**, then click **Search**. ![](img5.png)
