--- title: "Update or Insert Group" --- # Update or Insert Group > >
You can update a row or insert a new row into the database when a key pair combination does not exist. This eliminates the need to have a database that has every possible option considered in its original design. Because of the **insert row when not present** setting, the group will insert a new record whenever the designated ID doesn't exist. Afterwards, it will update the rows in the table that are associated with the key/value references as shown in this example. ## Update or Insert a New Row into the Database 1. In the Project Browser, right-click on Transaction Groups and select **New Standard Group**. ![Update or Insert a New Row into the Database Step 1](update-or-insert-a-new-row-into-the-database-step-1.png) 2. Give the group a name and click **Create Group**. 3. Drag a group of tags into the groups **Basic OPC/Group Items** section. ![Update or Insert a New Row into the Database Step 3](update-or-insert-a-new-row-into-the-database-step-3.png) 4. Change one of the tags to be read-only by selecting **Read Only** from the tag's **Target Name** column. ![Update or Insert a New Row into the Database Step 4](update-or-insert-a-new-row-into-the-database-step-4.png) 5. In the group's **Action** tab, in the **Table action** area, select the **update/select** radio button and the **key/value pairs** radio button. ![Update or Insert a New Row into the Database Step 5](update-or-insert-a-new-row-into-the-database-step-5.png) 6. Click the **Add** (![Add Icon](add-icon.png)) icon. 1. For the **Column**, select the database table ID column. 2. For the **Value** column, select the read-only tag. 3. Select **Insert row when not present** check box at the bottom of the **Table action** area. 7. Select the group, and click **Enabled**. 8. Save the project to start the group.
