--- title: "Agent Tasks" --- # Agent Tasks > Once the Gateway Network is up, and there is at least one Controller and one Agent configured, there are a variety of actions that can be performed on your agents in the form of Agent Tasks. ## Using The Gateway Network Agent Tasks involve performing a specific task to one or more specific Agents. The Agent Tasks page contains three tabs: * Available Tasks which contain tasks waiting to run. * Running and Scheduled Tasks which include any tasks that are currently running or scheduled to be run. * Task History, which provides a list of all previously run tasks. There are many different types of tasks to choose from, but they mostly involve doing Gateway level actions such as taking a Gateway backup or activating a license. ## Create an Agent Task 1. To create an Agent task, go to the Controller, and select the **Config** section on the Gateway Webpage. 2. Scroll down to **Enterprise Administration** > **Agent Tasks**. This opens the Agent Tasks window. ![](2020-03-10_14-20-10.png) 3. Click the **Create new Gateway Task** link to create an agent task. ![](2020-03-11_13-36-02.png) The options for Agent tasks are listed in the following table. |Task|Description| |--|--| |Activate License |Activate a license key on selected agent Gateways.| |Collect Backup |Collect a Gateway backup from an agent machine.| |Install Modules | Install one or more modules on selected agent Gateways.| |Remote Agent Upgrade| Prepare a full system upgrade on selected agent Gateways.| |Restart Agent |Restarts the Ignition service on the agent machine.| |Restore Backup |Restore a Gateway backup on selected agent Gateways.| |Send Project |Distributes a project to remote servers. Replaces the project on the remote server as if an export/import was performed.| |Send Project Resources|Distributes project resources, like windows and templates, to remote servers. **Note**: This is typically performed from a controller Gateway to an agent Gateway, but you can also send project resources from agent Gateway to agent Gateway.| |Send Tags| Distributes controller tags to agents. | |Unactivate License|Unactivate a license key on selected agent Gateways.| |Update License|Update the license on selected agent Gateways.| 4. Select task and then click **Next**. The Task scheduling screen is displayed. Tasks can then be scheduled to run in a few different ways depending on your needs. In the example below, the task is set to execute twice per day. Cron Expressions starting with the "/", "-", or "," characters are no longer considered valid. ![](2020-03-10_13-46-08.png) 5. Click **Next**. The EAM wizard will guide you through setting up your task. 6. Lastly, a Task Summary window appears. If you're ready to go, click **Finish**. Your task will be submitted according to the schedule type you defined. ![](2020-03-10_14-05-13.png) ## Agent Task Status On the Status section of the Gateway Webpage there is a page called **EAM Tasks**. This page is useful, as it shows information on what tasks are currently running, which tasks are scheduled to run, and a history of tasks that have been run. The **EAM Tasks** page can be used to allow users to see what is going on with the various agents without giving them the ability to configure them. ![](2020-03-10_14-07-25.png) ## Retrying Agent Tasks Should a task fail, you can directly execute the task again without needing to set the task back up by using the **retry** option. 1. On the Gateway webpage, navigate to **Config** > **Enterprise Administration** > **Agent Tasks**. ![](2020-03-10_14-20-10.png) 2. Expand the **More** dropdown for the task you want to retry, and select **retry**. ![](image-2023-10-10_8-59-3.png) 3. The Gateway will ask for a confirmation. Click **Confirm**. ![](image-2023-10-9_12-6-23.png) The controller will now attempt to run the task again. ### Resuming Failed File Transfer Tasks If a task that involves file transfers fails to complete, Ignition will now resume the file transfer task when you choose the **retry** option. In this situation, Ignition will resume transferring the specified file(s) from the point where the process was interrupted. Currently, this feature is available only for the [Remote Upgrade](ignition-modules/enterprise-administration/agent-management/remote-upgrade/remote-upgrade.md) task.
