--- title: "system.util.jsonDecode" description: "Takes a JSON string and converts it into a Python object such as a list or a dictionary." --- # system.util.jsonDecode > Takes a JSON string and converts it into a Python object such as a list or a dictionary. This function is used in **Python Scripting**. ## Description Takes a JSON string and converts it into a Python object such as a list or a dictionary. If the input is not valid JSON, a string is returned. ## Client Permission Restrictions This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.util.jsonDecode(jsonString)` ### Parameters Type | Parameter | Description ------- | ------- | ------ String| `jsonString` | The JSON string to decode into a Python object. ### Returns **Any** - The decoded Python object. See the table below for a listing of how JSON objects are mapped to Python objects. ### Scope Gateway, Vision Client, Perspective Session ## JSON to Python Mapping The table below lists possible JSON types, and the Python types this function maps to. |JSON Type|Mapped Python Type| |--|--| |Boolean (true/false) |Boolean (True/False)| |String |String| |Numeric |Number (Float, Integer)| |null |None| |Array |List| |Object| Dictionary| ## Code Examples ```python title="Example #1" # The following example reads in a JSON string, and converts the string to a Python object. # The example attempts to read the JSON string from a text file, but this could easily be modified to read data from a web server. # Read the JSON string jsonString = system.file.readFileAsString("C:\tmp\\json.txt") # Decode the JSON string and store the results into a variable obj = system.util.jsonDecode(jsonString) # Do something with the results. The code below prints the datatype of the results to the console. print type(obj) ```
