--- title: "system.util.invokeAsynchronous" description: "Invokes (calls) the given Python function on a different thread." --- # system.util.invokeAsynchronous > Invokes (calls) the given Python function on a different thread. This function is used in **Python Scripting**. ## Description Invokes (calls) the given Python function on a different thread. This means that calls to invokeAsynchronous will return immediately, and then the given function will start executing asynchronously on a different thread. This is useful for long-running data intensive functions, where running them synchronously (in the GUI thread) would make the GUI non-responsive for an unacceptable amount of time. :::caution This function should not be used to asynchronously interacts with the GUI in Vision. This means interacting with window navigation, setting and getting component properties, showing error/message popups, and really any other methods that can interact with components and windows. If you need to do something with the GUI in Vision with this function, this must be achieved through a subsequent call to [system.util.invokeLater](appendix\scripting-functions\system-util\system-util-invokeLater.md). By contrast, this function is safe to use in the gateway, which also means calls from Perspective are safe. ::: ## Client Permission Restrictions This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.util.invokeAsynchronous(function, [args], [kwargs], [description])` ### Parameters Type | Parameter | Description ------- | ------- | ------ Callable | `function` | A Python function object that will be invoked in a newly created thread. List [Any]| `args` | A list or tuple of Python objects that will be provided to the called function as arguments. Equivalent to the * [operator](https://docs.python.org/release/2.7.1/tutorial/controlflow.html?highlight=unpacking#unpacking-argument-lists). [optional] Dictionary[String, Any]| `kwargs` | A dictionary of keyword argument names to Python object values that will be provided to the called function as keyword arguments. Equivalent to the ** [operator](https://docs.python.org/release/2.7.1/tutorial/controlflow.html?highlight=unpacking#unpacking-argument-lists). [optional] String| `description` | A description to use for the asynchronous thread. Will be displayed on the current scope's diagnostic view for scripts. For Vision and the Designer, this would be the "Scripts" tab of the Diagnostics popup. For Perspective and the Gateway scope, this would be the Gateway's [Running Scripts](platform/gateway/status/diagnostics-running-scripts/diagnostics-running-scripts.md) status page. [optional] ### Returns **Thread** - The executing [Thread](https://docs.oracle.com/en/java/javase/11/docs/api/java.base/java/lang/Thread.html). ### Scope Gateway, Vision Client, Perspective Session ## Code Examples ```python title="Example #1" # This code would do some data-intensive processing, and then call # back to the GUI to let it know that it is finished. # We use default function parameters to pass the root container into these # functions. (See a Python reference if you don't understand this) def longProcess(rootContainer = event.source.parent): # Do something here with the database that takes a long time results = ...( something ) # Now we'll send our results back to the UI def sendBack(results = results, rootContainer = rootContainer): rootContainer.resultsProperty = results system.util.invokeLater(sendBack) system.util.invokeAsynchronous(longProcess) #Note that this is 'longProcess' instead of 'longProcess()' ```
