--- title: "system.util.getVersion" description: "Returns the Ignition version number that is currently being run." --- # system.util.getVersion > Returns the Ignition version number that is currently being run. This function is used in **Python Scripting**. ## Description :::note If the version is from a nightly build or developer version that is not yet released, the version number will come back as "Dev Version", for example: ![](getVersion.png) ::: ## Client Permission Restrictions This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.util.getVersion()` ### Parameters Nothing ### Returns **Version** - The currently running Ignition version number, as a [Version](https://sdk.inductiveautomation.com/javadoc/ignition81/latest/com/inductiveautomation/ignition/common/model/Version.html) object. ### Scope Gateway, Vision Client, Perspective Session The following table documents available attributes on the object. |Method and/or Attribute|Description|Return Type| |--|--|--| |.major|Returns only the major version number.8.0.2 returns 8|Integer| |.minor|Returns only the minor version number.8.0.2 returns 0|Integer| |isFutureVersion()|Takes in a string version number and returns whether the current version is greater than the given version (true or false). Note: this does account for Snapshot, RC or Beta versions.Version format expected: "X.X.X" ie "8.1.53" See example below.|Boolean| ## Code Examples ```python title="Example #1" # This code displays the name of the currently running Ignition version number. system.gui.messageBox("You are running project: %s" % system.util.getVersion()) ``` ```python title="Example #2" # This code displays whether a given version is older than the current version. currentVersion = system.util.getVersion() testVersion = "8.1.53" isFuture = currentVersion.isFutureVersion(testVersion) print "Your version (%s) is older than %s: %s" %(currentVersion, testVersion, isFuture) ```
