--- title: "system.util.getProjectName" description: "Returns the name of the project that is currently being run." --- # system.util.getProjectName > Returns the name of the project that is currently being run. This function is used in **Python Scripting**. ## Description Returns the name of the project that is currently being run. When run from the Gateway scope from a resource that originates from a singular project (reports, SFCs, etc.), will return that resources project. When called from a scope that does not have an associated project (a Tag Event Script), the function will return the name of the Gateway scripting project. If a Gateway scripting project has not been configured, then returns an empty string. ## Client Permission Restrictions This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.util.getProjectName()` ### Parameters Nothing ### Returns **String** - The name of the currently running project. ### Scope Gateway, Vision Client, Perspective Session ## Code Examples ```python title="Example #1" # This code would display the name of the currently running project system.gui.messageBox("You are running project: %s" % system.util.getProjectName()) ```
