--- title: "system.util.getConnectTimeout" description: "Returns the connect timeout in milliseconds for all client-to-gateway communication." --- # system.util.getConnectTimeout > Returns the connect timeout in milliseconds for all client-to-gateway communication. This function is used in **Python Scripting**. ## Description Returns the connect timeout in milliseconds for all client-to-gateway communication. This is the maximum amount of time that communication operations to the Gateway will be given to connect. The default is 10,000ms (10 seconds). ## Client Permission Restrictions This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.util.getConnectTimeout()` ### Parameters Nothing ### Returns **Integer** - The current connect timeout, in milliseconds. Default is 10,000 (ten seconds) ### Scope Vision Client ## Code Examples ```python title="Example #1" # This code would print out the current connect timeout print system.util.getConnectTimeout() ```
