--- title: "system.user.getNewUser" description: "Creates a new user object." --- # system.user.getNewUser > Creates a new user object. This function is used in **Python Scripting**. ## Description Creates a new user object. The user will not be added to the user source until [addUser](appendix\scripting-functions\system-user\system-user-addUser.md) is called. ## Client Permission Restrictions [Permission Type](ignition-modules\vision\vision-project-properties\vision-project-properties.md#vision-permissions-properties): User Management Client access to this scripting function is blocked to users that do not meet the role/zone requirements for the above permission type. This function is unaffected when run in the Gateway scope. ## Syntax `system.user.getNewUser(userSource, username)` ### Parameters Type | Parameter | Description ------- | ------- | ------ String| `userSource` | The name of the user source in which to create a user. String| `username` | The username for the new user. Does not check if the username already exists or is valid. ### Returns **User** - The new user, as a [User](https://sdk.inductiveautomation.com/javadoc/ignition81/latest/com/inductiveautomation/ignition/common/user/User.html) object. Refer also to the [PyUser](https://sdk.inductiveautomation.com/javadoc/ignition81/latest/com/inductiveautomation/ignition/common/user/PyUser.html) class. ### Scope Gateway, Vision Client, Perspective Session ## Code Examples ```python title="Example #1" # Get new user. userToGet = system.user.getNewUser("AcmeWest", "mTrejo") # Add some contact info. contactInfo = {"email":"mTrejo@acmewest.com","sms": "5551234"} userToGet.addContactInfo(contactInfo) userToGet.set("password", "mypassword") # Adds a user to the AcmeWest usersource. system.user.addUser("AcmeWest", userToGet) ``` ```python title="Example 2" # Util for printing the responses. def printResponse(responseList): if len(responseList) > 0: for response in responseList: print "", response else: print " None" # Make a brand new 'blank' user. Not saved until we save. user = system.user.getNewUser("", "myAwesomeUser") # Let's fill in some fields. Note we have two ways to access property names. user.set("firstname", "Naomi") user.set(user.LastName, "Nagata") user.set("password", "1234567890") # We can add contact info one at a time. Up to the script user to make sure the type is legit. user.addContactInfo("email", "naomi@roci.com") # We can add a lot of contact info. contactInfo = {"email":"ignition_user@mycompany.com","sms": "5551212"} user.addContactInfo(contactInfo) # We can delete contact info. Only deletes if both fields match. user.removeContactInfo("sms", "5551212") # We can add a role. If the role doesn't already exist, user save will fail, depending on user source. user.addRole("Mechanic") # We can add a lot of roles. roles = ["Administrator", "Operator"] user.addRoles(roles) # We can remove a role. user.removeRole("Operator") # We can add a schedule adjustment too. date2 = system.date.now() date1 = system.date.midnight(date2) user.addScheduleAdjustment(date1, date2, False, "An adjustment note") # We can make a bunch of adjustments and add them en-masse. date3 = system.date.addDays(date2, -4) adj1 = system.user.createScheduleAdjustment(date3, date2, True, "Another note") adj2 = system.user.createScheduleAdjustment(date3, date1, False, "") user.addScheduleAdjustments([adj1, adj2]) # and we can remove a schedule adjustment. All fields must match. user.removeScheduleAdjustment(date1, date2, True, "Some other note") # Finally, we will save our new user and print responses. response = system.user.addUser("", user) warnings = response.getWarns() print "Warnings are:" printResponse(warnings) errors = response.getErrors() print "Errors are:" printResponse(errors) infos = response.getInfos() print "Infos are:" printResponse(infos) ```
