--- title: "system.serial.readLine" description: "Attempts to read a line from a serial port." --- # system.serial.readLine > Attempts to read a line from a serial port. This function is used in **Python Scripting**. ## Description Attempts to read a line from a serial port. A "line" is considered to be terminated by either a line feed ('\n'), a carriage return ('\r'), or a carriage return followed immediately by a line feed. The function will wait until the timeout period for a terminator. If the timeout is reached before the line is properly terminated, then the buffer will be dumped, possibly resulting in data loss. ## Client Permission Restrictions This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.serial.readLine(port [, timeout] [, encoding])` ### Parameters Type | Parameter | Description ------- | ------- | ------ String| `port` | The previously configured serial port to use. Integer| `timeout` | Maximum amount of time, in milliseconds, to block before returning. Default is 5000. [optional] String| `encoding` | The String encoding to use. Default is UTF8. [optional] ### Returns **String** - A line of text. ### Scope Gateway, Vision Client, Perspective Session ## Code Example ```python title="Code Snippet" # This example will read from the "COM1" port and set the timeout to 10000 milliseconds. port = "COM1" timeout = 10000 system.serial.readLine(port,timeout) ```
