--- title: "system.serial.closeSerialPort" description: "Closes a previously opened serial port." --- # system.serial.closeSerialPort > Closes a previously opened serial port. This function is used in **Python Scripting**. ## Description Closes a previously opened serial port. Returns without doing anything if the named serial port is not currently open. Will throw an exception if the port is open and cannot be closed. ## Client Permission Restrictions This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.serial.closeSerialPort(port)` ### Parameters Type | Parameter | Description ------- | ------- | ------ String | `port` | The name of the serial port, e.g., "COM1" or "dev/ttyS0". ### Returns Nothing ### Scope Gateway, Vision Client, Perspective Session ## Code Examples ```python title="Code Snippet - Using a Literal Value" # This example will close a port called "COM1". system.serial.closeSerialPort("COM1") ``` ```python title="Code Snippet - Using a Variable" # This example will close a port using a variable called port that has a value of "COM1" port = "COM1" system.serial.closeSerialPort(port) ```
