--- title: "system.roster.getRoster" description: "Returns the roster corresponding to the given name." --- # system.roster.getRoster > Returns the roster corresponding to the given name. This function is used in **Python Scripting**. ## Description Returns the roster corresponding to the given name. You can call getUsers() to access a list of User objects in the RosterModel. Call getDescription() to access the Description field of the specified roster. ## Syntax `system.roster.getRoster(rosterName)` ### Parameters Type | Parameter | Description ------- | ------- | ------ String | `name` | The name of the roster to get the RosterModel object from. ### Returns **RosterModel** - The RosterModel object of the given roster name. ### Scope Gateway, Perspective Session ## Code Examples ```python title="Code Snippet" # This example gets the RosterModel object from a roster called "some roster" when a Button is pressed and prints the object to the browser console. roster = system.roster.getRoster("some roster") system.perspective.print(roster) ```
