--- title: "system.roster.createRoster" description: "Creates a roster with the given name and description, if it does not already exist." --- # system.roster.createRoster > Creates a roster with the given name and description, if it does not already exist. This function is used in **Python Scripting**. ## Description This function was designed to run in the Gateway and in Perspective sessions. If creating rosters from Vision clients, use [system.alarm.createRoster](../system-alarm/system-alarm-createRoster.md) instead ## Syntax `system.roster.createRoster(name, description)` ### Parameters Type | Parameter | Description ------- | ------- | ------ String| `name` | The name of the roster to create. String| `description` | The description for the roster. May be None, but the parameter is mandatory. ### Returns Nothing ### Scope Gateway, Perspective Session ## Code Examples ```python title="Code Snippet" # Create an empty roster with a description. system.roster.createRoster("rosterEast", "East plant user roster") # Create an empty roster roster without a description. system.roster.createRoster("rosterWest", None) ```
