--- title: "system.report.getReportNamesAsDataset" description: "Gets a data of all reports for a project." --- # system.report.getReportNamesAsDataset > Gets a data of all reports for a project. This function is used in **Python Scripting**. ## Description Gets a data of all reports for a project. Throws an IllegalArgumentException when any of the following occurs: If the project name is omitted in the Gateway scope, project does not exist. ## Client Permission Restrictions This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax :::note This function accepts [keyword arguments](platform\scripting\python-scripting\user-defined-functions.md#keyword-arguments). ::: `system.report.getReportNamesAsDataset([ project], [includeReportName])` ### Parameters Type | Parameter | Description ------- | ------- | ------ String| `project` | The name of the project where the reports are located. Optional in client scope. Boolean| `includeReportName` | When set to False, the end of Path does not include the report name. Default is True. [optional] ### Returns **Dataset** - A dataset of report paths and names for the project. Returns an empty dataset if the project has no reports. ### Scope Gateway, Vision Client, Perspective Session ## Code Examples ```python title="Code Snippet" # Gets a dataset of reports for the current project and displays # them in a Tree View component. event.source.parent.getComponent('Tree View').data = system.report.getReportNamesAsDataset() ```
