--- title: "system.project.getProjectName" description: "Returns the name of the project where the function was called from." --- # system.project.getProjectName > Returns the name of the project where the function was called from. This function is used in **Python Scripting**. ## Description Returns the name of the project where the function was called from. When called from the Gateway scope from a resource that originates from a singular project (reports, SFCs, etc.), will return that resources project. Resources that run in the Gateway scope, but are configured in a singular project (such as a report), will use that project's name. When called from a scope that does not have an associated project (a Tag Event Script), the function will return the name of the Gateway scripting project. If a Gateway scripting project has not been configured, then returns an empty string. ## Client Permission Restrictions This scripting function has no [Client Permission](ignition-modules\vision\vision-project-properties\vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.project.getProjectName()` ### Parameters Nothing ### Returns **String** - The name of the currently running project. ### Scope Gateway, Vision Client, Perspective Session ## Code Example ```python title="Code Snippet" # This code displays the name of the currently running project to the appropriate console, # depending on scope (Designer console, Gateway console, etc.). system.util.getLogger("myLogger").warn("You are running project: %s" % system.project.getProjectName()) ```
