--- title: "system.perspective.toggleDock" description: "Toggles a docked view." --- # system.perspective.toggleDock > Toggles a docked view. This function is used in **Python Scripting**. ## Description ## Syntax `system.perspective.toggleDock(id, [sessionId], [pageId])` ### Parameters Type | Parameter | Description ------- | ------- | ------ String | `id` | The unique, preconfigured 'Dock ID' for the docked view. Is specified when a view is assigned as docked for a particular page (in Page Configuration). String | `sessionId` | Identifier of the Session to target. If omitted, the current Session will be used automatically. When targeting a different session, then the pageId parameter must be included in the call. [optional] String | `pageId` | Identifier of the Page to target. If omitted, the current Page will be used automatically. [optional] Dictionary[String, String] | `params` | Parameters that can be passed into the docked view. Must match the docked views View Parameters. [optional] ### Returns Nothing ### Scope Gateway, Perspective Session :::note This function will only work in the Gateway scope if both `sessionId` and `pageId` are supplied to the call. ::: ## Code Examples ```python title="Code Snippet" # Toggles a docked view with ID "myDockID". We are passing in two parameters, called "myParam" and "myParam2". system.perspective.toggleDock('myDockID', params = {'myParam':1,'myParam2':'Test'}) ```
