--- title: "system.net.httpDelete" description: "Performs an HTTP DELETE to the given URL." --- # system.net.httpDelete > Performs an HTTP DELETE to the given URL. This function is used in **Python Scripting**. ## Description Keep in mind that [JRE proxy settings](https://docs.oracle.com/en/java/javase/11/docs/api/java.base/java/net/doc-files/net-properties.html#Proxies) will influence how these functions conduct their network activities. ## Client Permission Restrictions This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax :::tip This function accepts [keyword arguments](platform/scripting/python-scripting/user-defined-functions.md#keyword-arguments). ::: `system.net.httpDelete(url, [contentType], [connectTimeout], [readTimeout], [username], [password], [headerValues], [bypassCertValidation])` ### Parameters Type | Parameter | Description ------- | ------- | ------ String| `url` | The URL to send the request to. String| `contentType` | [Optional] The MIME type used in the HTTP 'Content-type' header. Int| `connectTimeout` | [Optional] The timeout for connecting to the URL in milliseconds. Default is 10,000 Int| `readTimeout` | [Optional] The read timeout for the operation in milliseconds. Default is 60,000. String| `username` | [Optional] If specified, the call will attempt to authenticate with basic HTTP authentication. String| `password` | [Optional] The password used for basic HTTP authentication, if the username parameter is also present. PyDictionary| `headerValues` | [Optional] A dictionary of name/value pairs that will be set in the HTTP header. Boolean| `bypassCertValidation` | [Optional] If the target address in an HTTPS address, and this parameter is TRUE, the system will bypass all SSL certificate validation. This is not recommended, though is sometimes necessary for self-signed certificates. ### Returns **String** - The content returned for the DELETE operation. ### Scope Gateway, Vision Client, Perspective Session ## Code Example ```python title="Code Snippet" # This example attempts to perform a DELETE operation URL = "http://myURL/folder.resource" system.net.httpDelete(URL) ```
