--- title: "system.iec61850.cancel" description: "Cancels the selection of an SBO type control on a configured IEC 61850 device to prevent the operate command from performing." --- # system.iec61850.cancel > Cancels the selection of an SBO type control on a configured IEC 61850 device to prevent the operate command from performing. This function is used in **Python Scripting**. ## Description Cancels the selection of an SBO type control on a configured IEC 61850 device to prevent the [operate](system-iec61850-operate.md) command from performing. :::caution Cancel Function The Cancel function will clear a selection of a **Select Before Operate (SBO)** type control if an operate command is not desired to be executed on the selected control. This function can be used as a safety measure to prevent unintended operations. Always ensure that the **Check** parameter is properly set and understood before using this function, as it can influence the behavior of the **Control Interlock (CILO)** and **Synchrocheck (RSYN)** logical nodes in the **Intelligent Electronic Device (IED)**. ::: ## Client Permission Restrictions This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.iec81650.cancel(deviceName, mapParams)` ### Parameters Type | Parameter | Description ------- | ------- | ------ String| `deviceName` | The name of the configured IEC 61850 device. PyDictionary| `mapParams` | Control parameters dictionary that requires the following keys to be specified: name, T, orCat, orIdent, Check, and Test. These keys must match the params from the select function. If you do not know the required key value pairs, they can be found using the [getControlParams](system-iec61850-getControlParams.md) function. ### Returns No return value. ### Scope Gateway, Perspective Session ## Code Examples ```python title="Example #1" # This example cancels the selected control mapParams = {'name': u'SSSA_52AFA_FPRCTRL/CBCSWI1.Mod', 'T':1 'orCat': 0, 'orIdent': u'not-supported', 'Check': 0, 'Test': False} system.iec61850.select("IEC61850", mapParams, 1) # after the select function was applied, cancel if not needed. system.iec61850.cancel("IEC61850", mapParams) ```
