--- title: "system.groups.loadFromFile" description: "Loads a transaction group configuration from an xml export, into the specified project (creating the project if necessary)." --- # system.groups.loadFromFile > Loads a transaction group configuration from an xml export, into the specified project (creating the project if necessary). This function is used in **Python Scripting**. ## Description Loads a transaction group configuration from an xml export, into the specified project (creating the project if necessary). The mode parameter dictates how overwrites occur. :::note This function is scoped for Perspective Sessions, but since all scripts in Perspective run on the Gateway, the file must be located on the Gateway's file system. ::: ## Client Permission Restrictions This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax ` system.groups.loadFromFile(filePath, projectName, mode)` ### Parameters Type | Parameter | Description ------- | ------- | ------ String| `filePath` | The path to a valid transaction group xml or csv file. String| `projectName` | The name of the project to load into. int| `mode` | How duplicates will be handled. 0 = Overwrite, 1 = Ignore, 2 = Replace the existing project with this one. ### Returns Nothing ### Scope Gateway, Perspective Session ## Code Examples ```python title="Example #1 - Loading a Transaction Group Into a Project" # Note that backslashes are used in Windows filepaths, but are also escaped in Python. Thus, we use the double-backslashes here. path = "C:\\Users\\user\\Desktop\\group.xml" projName = "MyProject" # Read a Transaction Group from a file and overwrite any preexisting groups that match those in our file. system.groups.loadFromFile(path, projName, 0) ```
