--- title: "system.dnp3" --- # system.dnp3 > :::note > The following functions use [system.dnp3](appendix\scripting-functions\system-dnp3\system-dnp3.md) and the [Legacy DNP3 driver](ignition-modules\opc-ua\opc-ua-drivers\dnp3\legacy-dnp3-driver\legacy-dnp3-driver.md). See [system.dnp](appendix\scripting-functions\system-dnp\system-dnp.md) for [DNP3](ignition-modules\opc-ua\opc-ua-drivers\dnp3\dnp3.md) functions using the [DNP3 driver](ignition-modules\opc-ua\opc-ua-drivers\dnp3\dnp3-driver\dnp3-driver.md). > ::: ## DNP3 Functions The following functions give you access to interact with the DNP3 devices. ### Functions by Scope ## Constants * system.dnp3.NUL = 0 * system.dnp3.PULSE_ON = 1 * system.dnp3.PULSE_OFF = 2 * system.dnp3.LATCH_ON = 3 * system.dnp3.LATCH_OFF = 4 * system.dnp3.CLOSE = 1 * system.dnp3.TRIP = 2 ## Status Codes Many of the dnp3 functions return a status code. Those codes and their meaning are listed below. | Code Number | Identifier Name | Description | | ----------- | ------------------ | ---------------- | | 0 | SUCCESS | Request accepted, initiated, or queued. | | 1 | TIMEOUT | Request no accepted because the operate message was received after the arm timer timed out. The arm timer was started when the select operation for the same point was received. | | 2 | NO_SELECT | Request no accepted because no previous matching select request exists. (An operate message was sent to activate an output that was not previously armed with a matching select message). | | 3 | FORMAT_ERROR | Request not accepted because there were formatting errors in the control request (either select, operate, or direct operate). | | 4 | NOT_SUPPORTED | Request not accepted because a control operation is not supported for this point. | | 5 | ALREADY_ACTIVE | Request not accepted, because the control queue is full or the point is already active. | | 6 | HARDWARE_ERROR | Request not accepted because of control hardware problems. | | 7 | LOCAL | Request not accepted because Local/Remote switch is in Local position. | | 8 | TOO_MANY_OBJS | Request not accepted because too many objects appeared in the same request. | | 9 | NOT_AUTHORIZED | Request not accepted because of insufficient authorization. | | 10 | AUTOMATION_INHIBIT | Request not accepted because it was prevented or inhibited by a local automation process. | | 11 | PROCESSING_LIMITED | Request not accepted because the device cannot process any more activities than are presently in progress. | | 12 | OUT_OF_RANGE | Request not accepted because the value is outside the acceptable range permitted for this point. | | 13 to 125 | RESERVED | Reserved for future use. | | 126 | NON_PARTICIPATING | Sent in request messages indicating that the outstation will not issue or perform the control operation. | | 127 | UNDEFINED | Request not accepted because of some other undefined reason. |
