--- title: "system.db.setDatasourceMaxConnections" description: "Sets the Max Active and Max Idle parameters of a given database connection." --- # system.db.setDatasourceMaxConnections > Sets the Max Active and Max Idle parameters of a given database connection. This function is used in **Python Scripting**. ## Description Sets the *Max Active* and *Max Idle* parameters of a given database connection. ## Client Permission Restrictions [Permission Type](ignition-modules\vision\vision-project-properties\vision-project-properties.md#vision-permissions-properties): Datasource Management Client access to this scripting function is blocked to users that do not meet the role/zone requirements for the above permission type. This function is unaffected when run in the Gateway scope. ## Syntax `system.db.setDatasourceMaxConnections(name, maxConnections)` ### Parameters Type | Parameter | Description ------- | ------- | ----- String| `name` | The name of the database connection in Ignition. Integer| `maxConnections` | Sets the *Max Active* and *Max Idle* parameters of a given database connection. ### Returns Nothing ### Scope Gateway, Vision Client, Perspective Session ## Code Examples ```python title="Code Snippet - Setting the Max Connections of a Data Source" # Example 1: Enable a connection system.db.setDatasourceMaxConnections("MySQL", 20) ```
