--- title: "system.db.runSFNamedQuery" description: "Runs a named query through the store and forward system and to multiple datasources at the same time." --- # system.db.runSFNamedQuery > Runs a named query through the store and forward system and to multiple datasources at the same time. This function is used in **Python Scripting**. ## Description Runs a named query that goes through the [Store and Forward](platform\database-connections\store-and-forward\store-and-forward.md) system. Note that the number of parameters in the function is determined by scope. Both versions of the function are listed on this page. :::note Only Update Named Queries are allowed in Store and Forward. ::: ## Client Permission Restrictions This scripting function has no [Client Permission](ignition-modules\vision\vision-project-properties\vision-project-properties.md#vision-permissions-properties) restrictions. ## Gateway Scope Syntax `system.db.runSFNamedQuery([project], path, params)` ### Parameters Type | Parameter | Description ------- | ------- | ----- String| `project` | The project name the query exists in. [optional] String| `path` | The path to the Named Query to run. Note that this is the full path to the query, including any folders. Dictionary[String, Any]| `params` | A Python dictionary of parameters for the Named Query to use. ### Returns **Boolean** - Returns true if successfully sent to the Store and Forward system. ### Scope Gateway, Perspective Session ## Project Scope Syntax `system.db.runSFNamedQuery(path, params)` ### Parameters Type | Parameter | Description ------- | ------- | ----- String| `path` | The path to the Named Query to run. Note that this is the full path to the query, including any folders. Dictionary[String, Any]| `params` | A Python dictionary of parameters for the Named Query to use. ### Returns **Boolean** - Returns true if successfully sent to the Store and Forward system. ### Scope Vision Client ## Code Examples ```python title="Simple Example - Without Parameters" # This example runs a Named Query without any parameters in the Project scope. # The second argument in the function is NOT optional, so Named Queries that do not require a parameter # must still pass an empty dictionary as an argument. # Request the Named Query with an empty dictionary as the second parameter. system.db.runSFNamedQuery("folderName/myNamedQuery", {}) ``` ```python title="Gateway Scope Example" # This example runs a Named Query without any parameters in the Gateway scope. # The last argument in the function is NOT optional, so Named Queries that do not require a parameter # must still pass an empty dictionary as an argument. # Request the Named Query to execute. system.db.runSFNamedQuery("ProjectName", "folderName/myNamedQuery", {}) ``` ```python title="Simple Example - With Parameters" # This example runs a Named Query while passing some parameters in the Project scope. # The Named Query is assumed to have two parameters already defined on the Named Query: # param1 : A string # param2 : An integer # Create a Python dictionary of parameters to pass params = {"param1":"my string", "param2":10} # Run the Named Query system.db.runSFNamedQuery("myUpdateQuery", params) ```
