--- title: "system.db.runNamedQuery" description: "Runs a named query and returns the results." --- # system.db.runNamedQuery > Runs a named query and returns the results. This function is used in **Python Scripting**. ## Description Runs a Named Query and returns the results. Note that the number of parameters in the function is determined by scope. Both versions of the function are listed below. This function accepts [keyword arguments](platform\scripting\python-scripting\user-defined-functions.md). ## Client Permission Restrictions This scripting function has no [Client Permission](ignition-modules\vision\vision-project-properties\vision-project-properties.md#vision-permissions-properties) restrictions. ## Project Scope Syntax `system.db.runNamedQuery(path, [parameters], [tx], [getKey])` ### Parameters Type | Parameter | Description ------- | ------- | ----- String| `path` | The path to the named query to run. Note that this is the full path to the query, including any folders. Dictionary[String, Any]| `parameters` | A Python dictionary of parameters for the Named Query to use. [optional] String| `tx` | An transaction ID, obtained from [beginNamedQueryTransaction](appendix\scripting-functions\system-db\system-db-beginNamedQueryTransaction.md). If blank, it will not be part of a transaction. [optional] Boolean | `getKey` | Only used for Update Query types. A flag indicating whether or not the result should be the number of rows affected (getKey=0) or the newly generated key value that was created as a result of the update (getKey=1). Not all databases support automatic retrieval of generated keys. [optional] ### Returns **PyDataset** - The results of the Named Query as a [PyDataset](platform\scripting\python-scripting\variables-datatypes-and-objects\datasets.md#accessing-data-in-a-pydataset). **Any** - Prior to 8.1.29, the exact object returned depends on the Query Type property of the Named Query. Query Types are selected on the Authoring Tab of a Named Query, and typically return the following: * Query: A dataset * Scalar Query: An integer representing the number of rows affected * Update Query: An object matching the data type of the value returned ### Scope Vision Client, Perspective Session ## Gateway Scope Syntax `system.db.runNamedQuery(project, path, [parameters], [tx], [getKey])` ### Parameters Type | Parameter | Description ------- | ------- | ----- String| `project` | The project name the query exists in. String| `path` | The path to the Named Query to run. Note that this is the full path to the query, including any folders. Dictionary[String, Any]| `parameters` | A Python dictionary of parameters for the Named Query to use. [optional] String| `tx` | An optional transaction ID, obtained from [beginNamedQueryTransaction](appendix\scripting-functions\system-db\system-db-beginNamedQueryTransaction.md). If blank, will not be part of a transaction. [optional] Boolean| `getKey` | Only used for Update Query types. A flag indicating whether or not the result should be the number of rows affected (getKey=0) or the newly generated key value that was created as a result of the update (getKey=1). Not all databases support automatic retrieval of generated keys. [optional] ### Returns **Any** - The results of the query. The exact object returned depends on the Query Type property of the Named Query. Query Types are selected on the Authoring Tab of a Named Query, and typically return the following: * Query: A dataset * Scalar Query: An integer representing the number of rows affected * Update Query: An object matching the data type of the value returned ### Scope Gateway ## Code Examples ```python title="Example #1 Project Scope - Without Parameters" # This example runs a Named Query without any parameters in the Project scope. # Request the Named Query to execute. system.db.runNamedQuery("folderName/myNamedQuery") ``` ```python title="Example #2 Project Scope - With Parameters" # This example runs a Named Query while passing some parameters in the Project scope. # The Named Query is assumed to have two parameters already defined on the Named Query: # param1 : A string # param2 : An integer # Create a Python dictionary of parameters to pass. parameters = {"param1":"my string", "param2":10} # Run the Named Query. system.db.runNamedQuery("myUpdateQuery", parameters) ``` ```python title="Example #3 Gateway Scope" # This example runs a Named Query without any parameters in the Gateway scope. # Request the Named Query to execute. system.db.runNamedQuery("ProjectName", "folderName/myNamedQuery") ```
