--- title: "system.date.get*" description: "Extracts a unit of time from a date." --- # system.date.get* > Extracts a unit of time from a date. This function is used in **Python Scripting**. ## Description This function is a set of functions that include: |Function|Description| |---|---| |system.date.getMillis| Extracts the milliseconds from a date, ranging from 0-999.| |system.date.getSecond| Extracts the second from a date, ranging from 0-59.| | system.date.getMinute | Extracts the minutes from a date, ranging from 0-59. | |system.date.getHour12| Extracts the hour from a date. Uses a 12 hour clock, so noon and midnight are returned as 0.| |system.date.getHour24| Extracts the hour from a date. Uses a 24 hour clock, so midnight is zero.| |system.date.getDayOfWeek| Extracts the day of the week from a date. Sunday is day 1, Saturday is day 7.| |system.date.getDayOfMonth| Extracts the day of the month from a date. The first day of the month is day 1.| |system.date.getDayOfYear| Extracts the day of the year from a date. The first day of the year is day 1.| |system.date.getMonth |Extracts the month from a date, where January is month 0.| |system.date.getQuarter| Extracts the quarter from a date, ranging from 1-4.| |system.date.getYear |Extracts the year from a date.| |system.date.getAMorPM |Returns a 0 if the time is before noon, and a 1 if the time is after noon.| ## Client Permission Restrictions This scripting function has no [Client Permission](ignition-modules\vision\vision-project-properties\vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.date.get*(date)` ### Parameters Type | Parameter | Description ------- | ------- | ------- Date | `date` | The date to use. ### Returns **Integer** - An integer that is representative of the extracted value. ### Scope Gateway, Vision Client, Perspective Session ## Code Examples ```python title="Example #1" # This example would grab the current time, and print the current month. date = system.date.now() print system.date.getMonth(date) #This would print the current month. ``` ```python title="Example #2" # This example would create a date object, and print out the quarter of that date. date = system.date.getDate(2017, 3, 15) #This would print "Mon April 15 00:00:00 PDT 2016" print system.date.getQuarter(date) #This will print 2 ``` ```python title="Example #3" # This example can be placed on the action performed event of a button. # It will then grab the day of the week of the calendar component, # and enter the value returned into a numeric text field. date = event.source.parent.getComponent('Calendar').date event.source.parent.getComponent('Numeric Text Field').intValue = system.date.getDayOfWeek(date) ```
