--- title: "Vision - Alarm Journal Table Scripting Functions" --- # Vision - Alarm Journal Table Scripting Functions > This page details the various component and extension functions available for [Vision's Alarm Journal Table component](alarm-journal-table.md). ## Component Functions ### .print(fitWidth, headerFormat, footerFormat, showDialog, landscape) * Description * This specialized print function will paginate the table onto multiple pages. This function accepts keyword-style invocation. * Keyword Args * boolean **fitWidth** - If true, the table's width will be stretched to fit across one page's width. Rows will still paginate normally. If false, the table will paginate columns onto extra pages. (default = true) [optional] * String **headerFormat** - A string to use as the table's page header. The substring "{0}" will be replaced with the current page number. (default = None) [optional] * String **footerFormat** - A string to use as the table's page footer. The substring "{0}" will be replaced with the current page number. (default = "Page {0}") [optional] * boolean **showDialog** - Whether or not the print dialog should be shown to the user. Default is true. [optional] * boolean **landscape** - Used to specify portrait (0) or landscape (1) mode. Default is portrait (0). [optional] * Return * boolean - True if the print job was successful. ### .getAlarms() * Description * Returns a dataset of the alarms currently displayed in the Alarm Journal Table component. The columns will be: EventId, Source, DisplayPath, EventTime, State, Priority and IsSystemEvent * Keyword Args * None * Return * Dataset - A dataset of alarms. ## Extension Functions ### createPopupMenu * Description * Returns a popup menu that will be displayed when the user triggers a popup menu (right click) in the table. Use [system.gui.createPopupMenu()](appendix/scripting-functions/system-gui/system-gui-createPopupMenu.md) to create the popup menu. * Parameters * Component **self** - A reference to the component that is invoking this function. * List **selectedAlarmEvents** - The alarm events selected on the Alarm Status Table. For an individual alarmEvent, call alarmEvent.get('propertyName') to inspect. Common properties: 'name', 'source', 'priority'. * Return * JPopupMenu - A popup menu that was created with [system.gui.createPopupMenu()](appendix/scripting-functions/system-gui/system-gui-createPopupMenu.md) ### filterAlarm * Description * Called for each event loaded into the alarm status table. Return false to hide this event from the table. This code is executed in a background thread. * Parameters * Component **self** - A reference to the component that is invoking this function. * Alarm Event **alarmEvent** - The alarm event itself. Call alarmEvent.get('propertyName') to inspect. Common properties: 'name', 'source', 'priority'. * Return * Boolean ### onDoubleClicked * Description * Called when an alarm is double-clicked on to provide custom functionality. Does not return a value. * Parameters * Component **self** - A reference to the component that is invoking this function. * Alarm Event **alarmEvent** - The alarm event itself. Call alarmEvent.get('propertyName') to inspect. Common properties: 'name', 'source', 'priority'. * Return * None
