--- title: "Report - Line Shape" description: "The Line shape component can be used to display a straight line any where in a report." --- # Report - Line Shape > The Line shape component can be used to display a straight line any where in a report. The Line shape component can be used to display a straight line any where in a report. It can run north-south, east-west, or diagonally. Select the Line shape on the Report Component Palette to make it active, and click and drag to draw a Line any where in your Report Designer. Hold shift while dragging to force the angle of the line to a 45 or 90 degree angle. You can change the stroke style, color, width, pattern, and more. ![" "](lineShape.png) **Report Design Component Palette Icon** ![" "](lineShapeIcon.png) ## Properties ![" "](lineShapeProps.png) |Property|Description| |---|---| |Fill|If true, the shape will fill its space with color.| |Fill Color|If true is selected, the color that will fill the shape.| |Opacity|How opaque the fill color is, between 0 and 1.| |Stroke Style|What style of stroke or border to use: Hidden; Shape Outline; Border; Double. To learn more about stroke styles, refer to [Stroke and Fill Properties](ignition-modules\reporting\report-design\stroke-and-fill-properties-for-reports\stroke-and-fill-properties-for-reports.md).Color - Color to use for the stroke or border.Dash Pattern - A "Dashed Pattern" string to specify the nunber of pixels on and off. For example, "5,10"Width - Width of the stroke in pixels.| |Stroke|[Details for the chosen stroke](ignition-modules\reporting\report-design\stroke-and-fill-properties-for-reports\stroke-and-fill-properties-for-reports.md). Each Stroke has its own properties depending on the Stroke Style chosen.| |Roll|Number of degrees this shape is rotated clockwise.| |Scale X|Amount to scale the width of this shape. 1 is scale to 100%.| |Scale Y|Amount to scale the height of this shape. 1 is scale to 100%.| |URL| A link to attach to this reporting component. Will be a clickable hyperlink if the report is exported as a PDF. You can use the values below to link to internal pages.Page:Next - Navigates to the next page.Page:Back - Navigates to the previous page.Page:Number - Replace "Number" with a numeral. Navigates to the specified page.| |Visible|If true, the shape will be visible.| |X|Horizontal distance in pixels between the left edge of this shape and the left edge of the page.| |Y|Vertical distance in pixels between the upper edge of this shape and the top edge of the page.| |Stroke Color|Color of the line.| |Stroke Width|Width of the stroke in pixels.| ## Example This example demonstrates possible property values that result in two orange lines. ![" "](lineShapeExample.png) |Property|Value| |---|---| |Stroke Style|Border| |Stroke Color|FF8C00| |Border Bottom|True| |Border Top|True| |Stroke Width|5 pixels|
