--- title: "Navigating with the Horizontal Menu Component" --- # Navigating with the Horizontal Menu Component > The Horizontal Menu component enables you to build a menu structure by setting up multiple links to different page URLs from the component. Our example has a menu with links to three internal pages and one external page on the Internet. This example shows a Horizontal Menu with four items. Three items are linked to views within the Perspective project and the fourth is linked to a website. The third item in the list, Field Offices, has four subitems. ![](2020-07-20_15-32-49.png) ## Initial Project Setup To begin with we have created three views: **WestView**, **EastView**, and **Welcome**. They are each coordinate type views. As we create each new view, we checked the Page URL property and added a page name. |View Name | Page URL| |--|--| |WestView |/west_page| |EastView |/east_page| |Welcome |/| ![](2019-12-20_12-55-34.png) On Page Configuration, you'll note that each page is already set up with a Primary view. ![](2019-12-20_15-33-59.png) Now we're ready to start building the navigation. ## Set Up a Header View The first thing we'll set up is a view that will hold the Horizontal Menu component. We'll use this view as a header for our pages within this project. 1. In the Project Browser, right click on Views and select the **NewFolder** ![](2019-12-09_11-21-14.png) option. Name the folder "Header". 2. Right click on the Header folder and select the **NewView** ![](2019-12-09_11-21-03.png) option. * Name: **Horizontal-Menu-Nav** * Layout: **Coordinate** * Page URL: unchecked ![](2019-12-18_16-30-02.png) 3. Click **Create View**. 4. In the Property Editor for the view, set the **defaultSize** property as follows: * width: **800** * height: **50** 5. Drag a Horizontal Menu component onto the view. 6. In the Property Editor, set the Position Properties as follows: |Property| Value| |--|--| |position.x| 15| |position.y |10| |position.width |550| |position.height |30| 7. In the Property Editor, scroll down to style and click the **ModifyStyle** ![]() icon. 1. Expand the Text section and set the style options as follows: |Property| Value| |--|--| |props.style.fontWeight| bolder| |props.style.fontFamily |Verdana| |props.style.fontSize| 14px| 1. Expand the Border section and set the style options as follows: |Property| Value| |--|--| |props.style.borderStyle |solid| |props.style.borderColor |#555555| |props.style.borderRadius |16px| |All Corners |(selected)| Your Designer will look like this at this point: ![](2020-07-20_14-04-53.png) 8. Open Page Configuration by clicking on the **Settings** ![]() icon at the bottom left of the Designer window. 9. Under Page Configuration, click on **Shared Settings**. 10. In the header part of the page mockup, click on the **Add** ![]() icon. 11. Select the Horizontal-Menu-Nav view from the dropdown. ![](2020-07-20_14-33-35.png) 12. Click **OK**. The Horizontal-Menu-Nav view will now appear at the top of all pages in the project. ## Configure the Tabs in the Horizontal Menu Now let's set the properties for each of the four tabs in the Horizontal Menu. Each tab will have a display a name and an icon and will have a target page or website to open when clicked. 1. In the Property Editor, expand the items property and set the following for item 0: |Property| Value| |--|--| |props.items.0.enabled| true| |props.items.0.target| /west_page| |props.items.0.icon.path| material/explore| |props.items.0.icon.color| #D97700| |props.items.0.label| West Site| The Property Editor will look like this: ![](2020-01-03_16-01-37.png) 2. In the Property Editor, set the following for item 1: |Property| Value| |--|--| |props.items.1.enabled| true| |props.items.1.target |/east_page| |props.items.1.icon| material/store| |props.items.1.color | #D97700| |props.items.1.label| East Site| 3. In the Property Editor, set the following for item 2: :::note Do not set a props.items.2.target property value for this tab because we will set up dropdown tabs in the next section. ::: |Property| Value| |--|--| |props.items.2.enabled| true| |props.items.2.icon.path |material/landscape| |props.items.2.icon.color| #D97700| |props.items.2.label| Field Offices| 4. In the Property Editor, set the following for item 3: :::note This tab uses a website as its target, therefore it does not need to target a page within Perspective. ::: |Property| Value| |--|--| |props.items.3.enabled| true| |props.items.3.target |http://inductiveautomation.com/about/| |props.items.3.icon.path| material/people| |props.items.3.icon.color|#D97700| |props.items.3.label |About| ### Configure the Field Offices Tab in the Horizontal Menu The third tab in the Horizontal Menu is titled "Field Offices." Instead of navigating to one page, this tab has a dropdown menu with four options on it: Reservoir, Dock, Warehouse, and Surveillance. 1. To start, we created a new folder in Views called **Field**. ![](2020-01-03_16-28-16.png) 2. Within the Field folder, we create four views: **Reservoir**, **Dock**, **Warehouse**, and **Surveillance**. Make them Coordinate types and set up a page URL for each. |View Name|Page URL| |--|--| |Reservoir|/reservoir_page| |Dock |/dock_page| |Warehouse| /warehouse_page| |Surveillance| /surveillance_page| 3. Open the Horizontal-Menu-Nav view and select the Horizontal Menu component. 4. In the Property Editor, expand the properties for Item 2. ![](2019-12-20_15-47-11.png) 5. Select the props.items.2.items property. 6. Click the Add ![](2020-07-20_15-23-59.png) icon to add four items. 7. Set the properties for Item 0 as follows: |Property| Value| |--|--| |props.items.2.items.0.enabled| true| |props.items.2.items.0.target |/reservoir_page| |props.items.2.items.0.icon.path| material/rowing| |props.items.2.items.0.icon.color| #00ACAC| |props.items.2.items.0.label |Reservoir| The Property Editor will look like this: ![](2020-01-03_16-35-22.png) 8. Now we'll do the same for the other three items. Set the properties for Item 1 as follows: |Property| Value| |--|--| |props.items.2.items.1.enabled| true| |props.items.2.items.1.target| /dock_page| |props.items.2.items.1.icon.path| material/directions_boat| |props.items.2.items.1.icon.color| #9E6635| |props.items.2.items.1.label |Dock| 9. Set the properties for Item 2 as follows: |Property| Value| |--|--| |props.items.2.items.2.enabled |true| |props.items.2.items.2.target| /warehouse_page| |props.items.2.items.2.icon.path| material/local_shipping| |props.items.2.items.2.icon.color|#0000AC| |props.items.2.items.2.label| Warehouse| 10. Set the properties for item 3 as follows: |Property| Value| |--|--| |props.items.2.items.3.enabled| true| |props.items.2.items.3.target| /surveillance_page| |props.items.2.items.3.icon.path| material/videocam| |props.items.2.items.3.icon.color| #AAAAAA| |props.items.2.items.3.label |Surveillance| 11. Save your project. 12. Click **Tools** > **Launch Perspective** > **Launch Session**. 13. Click on the tabs in the header to view different pages. For our example, we have put a few components on each view. Here is an example of what the Field Offices > Reservoir page might look like: ![](2020-07-20_15-39-40.png)
