--- title: "Perspective - Text Area" description: "The Text Area component is suitable for multi-line text display and editing." --- # Perspective - Text Area > The Text Area component is suitable for multi-line text display and editing. ![](img1.png) **Component Palette Icon**: ![](img2.png) ## Description Suitable for multi-line text display and editing. Will scroll vertically on demand. Horizontal scroll is determined by the "wrap" property. ## Properties Most Properties have binding options. For more information on Bindings, see [Types of Bindings in Perspective](ignition-modules/perspective/working-with-perspective-components/bindings-in-perspective/bindings-in-perspective.md). This section only documents the Props Category of properties. The other Categories are described on the [Perspective Component Properties](ignition-modules/perspective/working-with-perspective-components/perspective-component-properties.md) page. | Name | Description | Property Type | | ------------------------- | -------------------- | -------------- | | text | Text to display. | value: string | | placeholder | Text displayed when Text Area is empty. | value: string | | enabled | If true, user is allowed to alter text. | value: boolean | | deferUpdates | When true, updates to props.text will be deferred until focus is lost or enter is pressed. | value: boolean | | rejectUpdatesWhileFocused | When true, props.text will not accept updates from external sources while focused. | value: boolean | | resize | Sets whether text is resizable, and if so, in which direction: none, both, horizontal, or vertical. | value: string | | wrap | Specifies how to wrap text: hard, soft, or off. (Soft wrap is the break resulting from a line wrap or word wrap. Hard wrap is an intentional break, which moves text to the next line, or creates a new paragraph). | value: string | | style | Sets a style for this component. Full menu of [style options](appendix/reference-pages/style-reference.md) is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a [style class](ignition-modules/perspective/styles/style-classes/style-classes.md). | object | | spellcheck | When true, text containing potential spelling errors will be underlined in red while the text is being edited in a launched session. Be aware there may be some slight behavioral differences in spellcheck error detection depending on the session browser. | value: boolean | ## Component Events The [Perspective Event Types Reference](appendix/reference-pages/perspective-event-types-reference.md) page describes all the possible component event types for Perspective components. Not all component events support each Perspective component. The [Component Events and Actions](ignition-modules/perspective/working-with-perspective-components/component-events-and-actions.md) page shows how to configure events and actions on a Perspective component. Component scripting is handled separately and can be accessed from the Component menubar or by right clicking on the component. ## Example ![](img3.png) This example shows the Text Area in two states: the top image is with text entered and the bottom image is without text entered. |Property|Value| |--|--| |props.text |Data Point 01: xy4, zBeta 3Data Point 02: xy12, zBeta 45Notes: Example of how a longer sentence can wrap (or not) around to the next line. Enter was pressed between each of these three lines.| |props.placeholder |Lab Data Entry| |props.wrap| off|
