--- title: "Perspective - Dropdown" description: "The Dropdown component is a great way to display a list of choices in a limited amount of space." --- # Perspective - Dropdown > The Dropdown component is a great way to display a list of choices in a limited amount of space. ![](img1.png) **Component Palette Icon**: ![](img2.png) ## Description The Dropdown component is a great way to display a list of choices in a limited amount of space. The current selection is shown, and the choices are presented when the user clicks on the dropdown button. There is also the capability to search for an element by typing the name of that element in the dropdown field. If the element is present, it will appear as you are typing and you can select it. If the element doesn't exist, you can define text to display that the text is not found by configuring the **noResultsText** property. The choices that are displayed in the Dropdown depend on what Elements are defined in the **options** property of the Property Editor. The **placeholder** property defines what text is shown before any of the choices are selected. For example, you can have the word 'Select...' to inform the user to select any of the Elements from the dropdown list. There is also a **multiSelect** property which allows the user to select multiple elements from the dropdown. Selected elements can be deleted by clicking the 'x' icon. The Dropdown component has two pre-configured [variants](../../../../../ignition-modules/perspective/working-with-perspective-components/working-with-perspective-components.md): * Single Selection: Default layout that displays a list of choices of which the user can select one. * Multi-Selection: Layout with a list of choices of which the user can select more than one. ## Properties Most Properties have binding options. For more information on Bindings, see [Types of Bindings in Perspective](ignition-modules/perspective/working-with-perspective-components/bindings-in-perspective/bindings-in-perspective.md). This section only documents the Props Category of properties. The other Categories are described on the [Perspective Component Properties](ignition-modules/perspective/working-with-perspective-components/perspective-component-properties.md) page. | Name | Description | Property Type | | ------------------- | --------------- | ------------- | | value | The result of current selections (input) after any processing. | variable, based on which item in props.options property is selected. | | options | An array of objects for each dropdown option.**value**: Actual value to be matched by the input or selection.The type of this property is initially a Value-type, but it can be converted to an Object-type or Array-type. Doing so will populate the PROPS.value property with the entire object/array, allowing a single selection on the dropdown to return multiple values. Property type is variable. **Note**: Each option must have a unique value. **label**: Text to display in the menu representing this option. Value is string.**isDisabled**: Whether this option is currently disabled from selection. If set to true, option will not be selectable, and will use a grey font assuming another text color isn't being applied. Value is boolean. |array| | multiSelect | Enable multiple selected values. Default is false. | value: boolean | | placeholder | Settings for the text displayed when value is empty. Click to see the [placeholder properties](#placeholder-properties). | object | | enabled | If set to false, component is disabled. Field will not focus and dropdown will not be interactive.**Note:** If the component is disabled, scripts can still run on the component. For example, if you add a script action to the [onClick](https://docs.inductiveautomation.com/display/DOC81/Component+Events+and+Actions) event, the script will fire when the user clicks on the Dropdown. | value: boolean | | search | Enter text to start search.**enabled**: Whether options are searchable by typing text into the field. Default is true. Value is boolean.**matching**: Whether search string must match from the start or may match any position of an option: start or any. Value is string.**noResultsText**: Text to display in dropdown when no option matches the search. Default is "No results found." Value is string.**searchParam**: The text being searched for. Value is string.| object | | showClearIcon | Whether to display a button that the user can use to clear the selection. Default is false.| value: boolean | | allowCustomOptions | Whether a user may enter a custom value to be submitted. Default is false. While set to True, typing a value that doesn't match one of the existing options from the session will provide the user with a "Create" option. Selecting the Create option will set `props.value` to the new option. Creating a custom option in this way does not change the value of `props.options`. The custom option is simply a means to allow the user to type a custom value into the component. | value: boolean | | textAlign | Aligns the value(s) and/or placeholder text displayed within the dropdown. Valid values are left, center, and right. textAlign within the dropdown modal itself may be overridden or set separately using props.dropdownOptionStyle.textAlign. | value: string | | minMenuHeight | Minimum height of the dropdown menu. If the minimum height is not available under the component, and space is available above the component, the dropdown will flip to display options above the component. Default value is 150. | value: numeric | | maxMenuHeight | Maximum height of the dropdown menu before it becomes scrollable. Default value is 350. | value: numeric | | style | Sets a style for this component. Full menu of [style options](appendix/reference-pages/style-reference.md) is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a [style class](ignition-modules/perspective/styles/style-classes/style-classes.md).| object | | dropdownOptionStyle | Sets a style for the dropdown options. Full menu of [style options](appendix/reference-pages/style-reference.md) is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a [style class](ignition-modules/perspective/styles/style-classes/style-classes.md).| object | ### placeholder Properties | Name | Description | Property Type | | ------------------- | --------------- | ------------- | |text |Prompt text to display when no options are selected.| value: string| |color| Color of placeholder text. Can be chosen from color wheel, chosen from color palette, or entered as RGB or HSL value. See Color Selector. |color| |icon| Settings for an icon used as a placeholder.**path**: Shorthand path to the icon source. Format is library/iconName. The materials icon library is a the primary source for icons, see https://fonts.google.com/icons?selected=Material+Icons. Value is string.**color**: Color of the placeholder icon, if it exists. Can be chosen from color wheel, chosen from color palette, or entered as RGB or HSL value. See [Color Selector](../../../../reference-pages/color-selector-reference/color-selector-reference.mdx).**style**: Sets a style for this component. Full menu of [style options](appendix/reference-pages/style-reference.md) is available for text, background, margin and padding, border, shape and miscellaneous. Three additional available settings are as follows:**margin**: Margin around the icon, in pixels. Default is 0px 8px -3px 0px. Value is numeric.**width**: Width of the icon in pixels. Default is 16px. Value is numeric.**height**: Height of the icon in pixels. Default is 16px. Value is numeric.|object| ## Component Events The [Perspective Event Types Reference](appendix/reference-pages/perspective-event-types-reference.md) page describes all the possible component event types for Perspective components. Not all component events support each Perspective component. The [Component Events and Actions](ignition-modules/perspective/working-with-perspective-components/component-events-and-actions.md) page shows how to configure events and actions on a Perspective component. Component scripting is handled separately and can be accessed from the Component menubar or by right clicking on the component. ## Examples ### Example 1 ![](img3.png) | Property | Value | | ------------------------------------ | ------------------------------ | | props.options.0.value | `[default]_Dairy_/Bldg25/valve1` | | props.options.0.label | `Valve 1` | | props.options.1.value | `[default]_Dairy_/Bldg25/valve2` | | props.options.1.label | `Valve 2` | | props.options.2.value | `[default]_Dairy_/Bldg25/valve3` | | props.options.2.label | `Valve 3` | | props.options.3.value | `[default]_Dairy_/Bldg25/valve4` | | props.options.3.label | `Valve 4` | | props.placeholder.text | `Select a Valve...` | | props.placeholder.color | `#0000AC` | | props.placeholder.icon.path | `material/grade` | | props.placeholder.icon.color | `#008000 ` | | props.style.borderStyle | `solid` | | props.style.color | `#0000D9` | | props.style.fontFamily | `garamound` | | props.style.fontSize | `16px` | | props.style.fontWeight | `bold` | | props.style.borderWidth | `2px` | | props.style.borderColor | `#008000` | | props.style.borderRadius | `8px` | | props.dropdownOptionStyle.color | `#008000 ` | | props.dropdownOptionStyle.fontSize | `14px` | | props.dropdownOptionStyle.fontWeight | `bold` | | props.dropdownOptionStyle.textAlign | `right` | ### Example 2 In this example, we have a dropdown list with an expression binding on the options property. There is also a label on the view with the word "Email" as its text. A default email address of j_smith@companyname.com is set as the starting value for the component. ![](img4.png) As the user starts entering characters for an email address, the dropdown list provides typeahead options of the entered text plus three possible email options, @'cn.com', '@companyname.com', or '@gmail.com'. ![](img5.png) | Property | Value | | ------------ | ------------- | |value |`j_smith@companyname.com`| |options |(Bound to an expression. See example below.)| |props.search.enabled| `true`| ```python title="transform code" # suggest auto-completed options for an email address options = [] # skip if blank if value: # check for @ symbol and suggest email address if not present if "@" not in value: options.append({ "value":value+"@cn.com", "label":value+"@cn.com"}) options.append({ "value":value+"@gmail.com", "label":value+"@gmail.com"}) options.append({ "value":value+"@companyname.com", "label":value+"@companyname.com"}) # check for extension (.com) and suggest extensions if not present elif ".com" not in value and ".net" not in value and ".org" not in value: options.append({ "value":value+".com", "label":value+".com"}) options.append({ "value":value+".net", "label":value+".net"}) options.append({ "value":value+".org", "label":value+".org"}) # return a list of suggested options return options ``` ![](img6.png)
