--- title: "Perspective - Embedded View" description: "The Embedded View component allows you to include an entire view inside another." --- # Perspective - Embedded View > The Embedded View component allows you to include an entire view inside another. ![](2020-04-22_11-42-04.png) **Component Palette Icon**: ![](2019-05-07_10-01-12.png) ## Description The Embedded View component allows you to include an entire view inside another. Using this component allows you to select a view to display, and to pass parameters into the view. Because of this, views can easily act as templates for information. For example, you could create a tank view and embed several into another, larger view that shows an overview of the facility. Using an Embedded View is different than a container because you cannot alter the contents of the view. A new container would allow you to create a new grouped set of components. :::caution Slow Performance Embedded views are convenient, but oversaturating your view may come with performance issues. Too many embedded views in a single view or too many nested embedded views, along with potential race conditions from passing parameters between embedded views may cause slow performance. ::: ## Properties Most Properties have binding options. For more information on Bindings, see [Types of Bindings in Perspective](ignition-modules/perspective/working-with-perspective-components/bindings-in-perspective/bindings-in-perspective.md). This section only documents the Props Category of properties. The other Categories are described on the [Perspective Component Properties](ignition-modules/perspective/working-with-perspective-components/perspective-component-properties.md) page. | Name | Description | Property Type | | ----- | --------- | -------------------- | | path | Path of the view to load in wrapper. If a path is present in the path property field, an Open View ![](image-2023-6-13_6-29-5.png) icon will appear that will navigate directly to the view when clicked. | value: string | | params | Parameters for the view. If passing parameters into the embedded view, the names here must match the parameters on that view. As of 8.1.4 a dropdown list of parameters is available when the user clicks the **Add Object Member** ![](2021-03-01_10-43-25-icon-ad-parm.png) icon. This makes it easy to add parameters from the embedded view. See also [Embedded Views](ignition-modules/perspective/views-in-perspective/embedded-views.md). ![](2021-03-10_11-45-25.png) | object | | useDefaultViewWidth | Use of view's default width instead of adjusting based on the content's width. | value: boolean | | useDefaultViewHeight | Use of view's default height instead of adjusting based on the content's width. | value: boolean| | loading | View loading settings. **order**: Controls when the embedded view loads: alongside the parent view loading (`with-parent`), or after the parent view finishes loading (`after-parent`). Default is with-parent. Generally speaking, `with-parent` is more efficient for the browser, but in some cases can feel slower overall. Alternatively, `after-parent` is generally less efficient for the browser and can add to the overall load time. However, since it allows the parent view to load first, `after-parent` may feel quicker since the topmost layer of views get started up sooner. Value is boolean.| object | | style | Sets a style for this component. Full menu of [style options](appendix/reference-pages/style-reference.md) is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a [style class](ignition-modules/perspective/styles/style-classes/style-classes.md). | object| ## Component Events The [Perspective Event Types Reference](appendix/reference-pages/perspective-event-types-reference.md) page describes all the possible component event types for Perspective components. Not all component events support each Perspective component. The [Component Events and Actions](ignition-modules/perspective/working-with-perspective-components/component-events-and-actions.md) page shows how to configure events and actions on a Perspective component. Component scripting is handled separately and can be accessed from the Component menubar or by right clicking on the component. ## Example ![](2019-08-13_11-50-27.png) In this example, there is a Map component and a Carousel component on the top of the page. Underneath them, we've placed an Embedded View component. The idea was to embed this overview to give users a quick visual reference to bigger picture trends for the site. This example assumes you have a view already created named "Pressure Trend Overview". The table below shows the properties for just the Embedded View. |Property| Value| Style Category| |--|--|--| |props.path| Pressure Trend Overview |N/A| |props.style.backgroundColor| #FFE8CC |background| |props.style.borderStyle| groove |border| |props.style.borderWidth| 6px |border|
