--- title: "Perspective - Linear Scale" description: "The Linear Scale component displays a series of tick marks and labels." --- # Perspective - Linear Scale > The Linear Scale component displays a series of tick marks and labels. ![](2018-12-07_14-21-40linrscle.png) **Component Palette Icon**: ![](2019-05-07_9-30-15.png) ## Description The Linear Scale component displays a series of tick marks and labels that represent a range between a minimum value and a maximum value. It also displays indicators that represent a value or range of values, correctly positioned on the linear scale. Linear Scale component allows floating point tick marks such as 0.25, 0.5, 0.75, 1.25, etc. ## Properties Most Properties have binding options. For more information on Bindings, see [Types of Bindings in Perspective](ignition-modules/perspective/working-with-perspective-components/bindings-in-perspective/bindings-in-perspective.md). This section only documents the Props Category of properties. The other Categories are described on the [Perspective Component Properties](ignition-modules/perspective/working-with-perspective-components/perspective-component-properties.md) page. | Name | Description | Property Type | | ---------- | ------------ | -------------- | | minValue | The minimum value displayed on the scale. | value: numeric | | maxValue | The maximum value displayed on the scale. | value: numeric | | majorTicks | Settings for the major tick marks on the scale. See the [majorTicks](#tick-child-properties) properties. | object | | minorTicks | Settings for the minor tick marks on the scale. See the [minorTicks](#tick-child-properties) properties. | object | | fineTicks | Settings for the fine tick marks on the scale. See the [fineTicks](#tick-child-properties) properties. | object | | labels | Displays of the numeric values of major tick marks. Options are as follows: **angle**: Rotation of the numeric labels. Default is 0. Value is numeric.**style**: Sets a style for the label. Full menu of [style options](appendix/reference-pages/style-reference.md) is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a [style class](ignition-modules/perspective/styles/style-classes/style-classes.md). | object | | indicators | Markers of special significance that can be placed along the scale. Click [here](perspective-linear-scale.md#indicators-child-properties) to see the indicators properties. | object | | mirror | Aligns the scale to the opposite side of the component. Default is false. | value: boolean | | reverse| Inverts the order of the scale values so min to max is ordered in reverse. Default is false (minimum to max). | value: boolean | | style | Sets a style for this scale. Full menu of [style options](appendix/reference-pages/style-reference.md) is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a [style class](ignition-modules/perspective/styles/style-classes/style-classes.md). | object | ### Tick Child Properties The following child properties apply to majorTicks, minorTicks, and fineTicks. | Name | Description | Property Type | | ------ | --------------------- | -------------- | | span | Distance between each tick mark of this type, in pixels. Default is 20. | value: numeric | | length | Length of each tick mark, in pixels. Default is 20. | value: numeric | | color | Color for the major ticks. Can be chosen from color wheel, chosen from color palette, or entered as RGB or HSL value. See [Color Selector.](appendix/reference-pages/color-selector-reference/color-selector-reference.mdx) | color | | stroke | Width of each tick mark, in pixels. Default is 1. | value: numeric | ### indicators Child Properties | Name | Description | Property Type | | -------------- |----| ---------------------- | | value | Numeric value along the scale where the indicator is placed or started. | value: numeric | | label | Text to display with the indicator. Default is "High". | value: string | | labelColor | Color of the indicator label. Can be chosen from color wheel, chosen from color palette, or entered as RGB or HSL value. See [Color Selector.](appendix/reference-pages/color-selector-reference/color-selector-reference.mdx) | color | | labelAngle | Rotational angle of the indicator label. | value: numeric | | color | Color of the indicator or the area making up the indicator. See [Color Selector.](appendix/reference-pages/color-selector-reference/color-selector-reference.mdx) | color | | stroke | If indicatorStyle is set to line or wedge, stroke is the width (in pixels) of the indicator. | value: numeric| | opacity | Opacity of the indicator. 0 is fully transparent, 1 is fully opaque. | value: numeric | | length | Length of the indicator as measured by its x value within the scale. Default is 25. | value: numeric | | indicatorStyle | Indicator style can be set to line, wedge, or range. Line is similar to a tick mark. Wedge displays a triangular shape. Range displays a rectangular range along the scale as measured by the property extent. Default is range. | value: string dropdown | | extent|If indicatorStyle is set to range, this is the extent along the scale that the indicator is placed. Value must be positive. Default is 15.| value: numeric | ## Component Events The [Perspective Event Types Reference](appendix/reference-pages/perspective-event-types-reference.md) page describes all the possible component event types for Perspective components. Not all component events support each Perspective component. The [Component Events and Actions](ignition-modules/perspective/working-with-perspective-components/component-events-and-actions.md) page shows how to configure events and actions on a Perspective component. Component scripting is handled separately and can be accessed from the Component menubar or by right clicking on the component. ## Example ![](2019-02-19_10-29-22-lnsc-ex-m.png) | Property | Value | | --------------------------------- | ------- | | props.maxValue | 120 | | props.minorTicks.span | 10 | | props.fineTicks.span | 5 | | props.indicators.0.value | 95 | | props.indicators.0.color | #D90000 | | props.indicators.0.extent | 25 | | props.indicators.1.value | 00 | | props.indicators.1.indicatorStyle | range | | props.indicators.1.color | #D9D900 | | props.indicators.1.extent | 20 | | props.indicators.2.value | 74 | | props.indicators.2.indicatorStyle | wedge | | props.indicators.2.color | #0000D9 |
