--- title: "Perspective - Barcode" description: "The Barcode component enables you to display text as a barcode." --- # Perspective - Barcode > The Barcode component enables you to display text as a barcode. ![](2020-02-19_16-44-21.png) **Component Palette Icon**: ![](2020-02-19_16-48-55.png) ## Description The Barcode component enables you to display text as a barcode. The component supports 105 different barcode types including Code 128, QR code, EAN-8, and ISBN. The Barcode component has two pre-configured [variants](ignition-modules/perspective/working-with-perspective-components/working-with-perspective-components.md): Code 128 and QR Code. ## Properties Most Properties have binding options. For more information on Bindings, see [Types of Bindings in Perspective](ignition-modules/perspective/working-with-perspective-components/bindings-in-perspective/bindings-in-perspective.md). This section only documents the Props Category of properties. The other Categories are described on the [Perspective Component Properties](ignition-modules/perspective/working-with-perspective-components/perspective-component-properties.md) page. | Name | Description | Property Type | | ------------- | ------------- | -------------- | | value | Value to be encoded as a barcode. | value: numeric | | type | What barcode specification to use, currently there are 105 formats supported including Code 128, QR code, EAN-8, and ISBN. Click here to see the [barcode specification options](perspective-barcode.md#barcode-specification-options). | value: string | | displayValue | If true, the barcode's value will be displayed as text. | value: boolean | | valuePosition | If displayValue is true, this property determines where the value should be displayed. Options are top or bottom; default is bottom. | value: string | | valueStyle | Sets a style for the display value for this component. Full menu of [style options](appendix/reference-pages/style-reference.md) is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a [style class](ignition-modules/perspective/styles/style-classes/style-classes.md). | object | | errorStyle | Sets a style for this component. Full menu of [style options](appendix/reference-pages/style-reference.md) is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a [style class](ignition-modules/perspective/styles/style-classes/style-classes.md). | object | | style | Sets an overall style for this component. Full menu of [style options](appendix/reference-pages/style-reference.md) is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a [style class](ignition-modules/perspective/styles/style-classes/style-classes.md). | object | ### Barcode Specification Options | A-B | C | D | E-G | | ------ | ------ | ----- | --- | | auspost azteccodeazteccodecompactaztecrunebc412 | channelcode,codablockf,code11code128code16kcode2of5code32code39code39extcode49code93code93extcodeonecoop2of5 | daftdatabarexpandeddatabarexpandedcompositedatabarexpandedstackeddatabarexpandedstackedcompositedatabarlimiteddatabarlimitedcompositedatabaromnidatabaromnicompositedatabarstackeddatabarstackedcompositedatabarstackedomnidatabarstackedomnicompositedatabartruncateddatabaretruncstedcompositedatalogic2of5datamatrixdatamatrixrectangulardatamatrixrectangularextensiondotcode | ean13ean13compositeean14ean2ean5ean8ean8compositeflattermarkengs1-128GS1-128gs1-128compositegs1-ccgs1datamatrixgs1datamatrixrectangulargs1northamericancoupongs1qrcode | | H-J | K-P | Q-Z | |---| --- | --| | hanxinhibcazteccodehibccodeablockfhibccode128hibccode39hibcdatamatrixhibcdatamatrixrectangularhibcmicropdf417hibcpdf417hibcqrcodeiata2of5identcodeindustrial2of5interleaved2of5isbnismnissnitf14japanpost | kixleitcodemailmarkmatrix2of5maxicodemicropdf417microqrcodemsionecodepdf417pdf417compactpharmacodepharmacode2planetplesseyposicodepostnetpzn | qrcoderationalizedCodabarrawroyalmailsscc18symboltelepentelepennumericultracodeupcaupcacompositeupceupcecomposite | ## Component Events The [Perspective Event Types Reference](appendix/reference-pages/perspective-event-types-reference.md) page describes all the possible component event types for Perspective components. Not all component events support each Perspective component. The [Component Events and Actions](ignition-modules/perspective/working-with-perspective-components/component-events-and-actions.md) page shows how to configure events and actions on a Perspective component. Component scripting is handled separately and can be accessed from the Component menubar or by right clicking on the component. ## Examples ### Example 1 ![](2020-02-20_13-11-14.png) |Property|Value| |--|--| |props.value| 014113910613| |props.type| upca| |props.displayValue |true| |props.valuePosition |bottom| |props.valueStyle.fontFamily| Verdana| |props.valueStyle.fontSize| 18px| ### Example 2 ![](2020-02-20_15-29-33.png) |Property|Value| |--|--| |props.value| http://inductiveautomation.com| |props.type |qrcode| |props.displayValue|true| |props.valuePosition| top| |props.valueStyle.color |#2747C7| |props.valueStyle.fontFamily|sans-serif| |props.valueStyle.fontSize| 14px| |props.valueStyle.fontWeight| bold| |props.style.paddingTop| 12px| |props.style.borderColor| D97700|
