--- title: "Perspective - Audio Scripting" --- # Perspective - Audio Scripting > This page details the various scripting, component, and extension functions available for Perspective's [Audio](appendix/components/perspective-components/perspective-display-palette/perspective-audio/perspective-audio.md) component. ## Component Events The [Perspective Event Types Reference](appendix/reference-pages/perspective-event-types-reference.md) page describes all the possible component event types for Perspective components. Not all component events support each Perspective component. The [Component Events and Actions](ignition-modules/perspective/working-with-perspective-components/component-events-and-actions.md) page shows how to configure events and actions on a Perspective component. Component scripting is handled separately and can be accessed from the Component menubar or by right clicking on the component. ### onPlay This event is fired when playback has begun. #### event * Object Path * event * Type * Null * Description * An empty event object. ### onPause This event is fired when playback has been paused. #### event * Object Path * event * Type * Null * Description * An empty event object. ### onError This event is fired when there is an error attempting to play the media file. :::caution This component event is designed to be used in tandem with a script action. Within the script action, special properties and methods are available on the **event** object, which is passed to the script action as a parameter. ::: #### event.errorMessage * Object Path * event.errorMessage * Type * String * Description * Error message when attempting to play the media file. ### onEnded This event is fired when playback has ended due to reaching the end of the media. #### event * Object Path * event * Type * Null * Description * An empty event object. ### onLoaded This event is fired when the first frame of the media has loaded. #### event * Object Path * event * Type * Null * Description * An empty event object. ### onRateChanged This event is fired when the playback rate of the media has changed. #### event * Object Path * event * Type * Null * Description * An empty event object. ## Component Functions ### .play() * Description * Plays the media file, triggering the onPlay component event. * Parameters * None * Return * Nothing ### .pause() * Description * Pauses the media file, triggering the onPause component event. * Parameters * None * Return * Nothing ### .replay() * Description * Replays the media file from the beginning. * Parameters * None * Return * Nothing ## Extension Functions This component does not have extension functions associated with it.
