--- title: "XY Chart Example - Candlestick Chart" --- # XY Chart Example - Candlestick Chart > This example demonstrates how to configure a candlestick chart. The candlestick chart needs five keys per entry on the chart: a key to represent the date of the entry and four keys that make up the candlestick. These four keys are called open, close, high, and low. These dedicated key properties are visible under the **series** when the render selection is set to candlestick, and therefore this chart does not require that the keys under **dataSources** use the exact naming conventions as shown on this page. ![](image2021-8-16_9-46-8.png) ## Configure a Candlestick Chart 1. Create an XY chart component and select it. 2. Copy the JSON content below, and paste it onto the chart component's **dataSources.example** property. ``` [ { "close": 6, "date": "2021-8-12 15:37:19", "high": 7, "low": 2, "open": 5 }, { "close": 7, "date": "2021-8-13 15:37:19", "high": 9, "low": 5, "open": 6 }, { "close": 5, "date": "2021-8-14 15:37:19", "high": 7, "low": 4, "open": 7 } ] ``` 3. Remove the legend by setting **legend.enabled** to false. 4. Rename **xAxes.0.name** to `dateAxis`. 5. Set **xAxes.0.label.text** to `Date`, to change the label on the x-axis. ![](image-2023-7-28_12-6-14.png) 6. Our chart only needs a single y-axis, so delete **yAxes.1**. 7. Set **yAxes.0.name** to `valuation`. 8. Set **yAxes.0.label.text** to `Value`. 9. Delete **series.1** since we only need a single series for this example. 10. Navigate to the **series.0.data** property and make sure the **source** is still `example` from the JSON string pasted in step 2. 11. Set **series.0.data.x** to the `date` key 12. Set **series.0.data.y** to the `close` key. 13. Set **series.0.xAxis** to the xAxes: `dateAxis`. 14. Set **series.0.yAxis** to the yAxes: `valuation`. 15. Set **series.0.render** to `candlestick`. 16. Expand the now visible candlestick properties and set the open, high, and low keys: * **series.0.candlestick.open**: set x to `date` and y to `open`. * **series.0.candlestick.high**: set x to `date` and y to `high`. * **series.0.candlestick.low**: set x, to `date` and y to `low`. ![](image-2023-7-28_13-7-6.png) Your candlestick chart is now ready. Note that the third entry is in red, while the first two are green. This is because that entry's close value is less than it's open value. ### Example Configuration The JSON string below can be used to replicate the example above. Simply copy the contents of the code block and paste it into a container in your Designer. ``` [ { "type": "ia.chart.xy", "version": 0, "props": { "legend": { "enabled": false }, "xAxes": [ { "name": "dateAxis", "label": { "enabled": true, "text": "Date", "color": "" }, "visible": true, "tooltip": { "enabled": true, "text": "", "cornerRadius": 3, "pointerLength": 4, "background": { "color": "", "opacity": 1 } }, "inversed": false, "render": "date", "category": { "break": { "enabled": false, "startCategory": "", "endCategory": "", "size": 0.05 } }, "date": { "baseInterval": { "enabled": false, "timeUnit": "hour", "count": 1, "skipEmptyPeriods": false }, "range": { "max": "", "min": "", "useStrict": false }, "break": { "enabled": false, "startDate": "", "endDate": "", "size": 0.05 }, "inputFormat": "yyyy-MM-dd kk:mm:ss", "format": "M/d" }, "value": { "range": { "max": "", "min": "", "useStrict": false }, "logarithmic": false, "break": { "enabled": false, "startValue": 0, "endValue": 100, "size": 0.05 }, "format": "#,###.##" }, "appearance": { "opposite": false, "inside": false, "labels": { "color": "", "opacity": 1 }, "grid": { "color": "", "opacity": 1, "dashArray": "", "minDistance": 60, "position": 0.5 }, "font": { "size": "", "weight": 500 } } } ], "yAxes": [ { "name": "valuation", "label": { "enabled": true, "text": "Value", "color": "" }, "visible": true, "tooltip": { "enabled": true, "text": "", "cornerRadius": 3, "pointerLength": 4, "background": { "color": "", "opacity": 1 } }, "inversed": false, "render": "value", "category": { "break": { "enabled": false, "startCategory": "", "endCategory": "", "size": 0.05 } }, "date": { "baseInterval": { "enabled": false, "timeUnit": "hour", "count": 1, "skipEmptyPeriods": false }, "range": { "max": "", "min": "", "useStrict": false }, "break": { "enabled": false, "startDate": "", "endDate": "", "size": 0.05 }, "inputFormat": "yyyy-MM-dd kk:mm:ss", "format": "M/d/yyyy HH:mm:ss" }, "value": { "range": { "max": "", "min": "", "useStrict": false }, "logarithmic": false, "break": { "enabled": false, "startValue": 0, "endValue": 100, "size": 0.05 }, "format": "#,###.##" }, "appearance": { "opposite": false, "inside": false, "labels": { "color": "", "opacity": 1 }, "grid": { "color": "", "opacity": 1, "dashArray": "", "minDistance": null, "position": 0.5 }, "font": { "size": "", "weight": 500 } } } ], "series": [ { "name": "process temp", "label": { "text": "Process Temp" }, "visible": true, "hiddenInLegend": false, "defaultState": { "visible": true }, "data": { "source": "example", "x": "date", "y": "close" }, "xAxis": "dateAxis", "yAxis": "valuation", "zIndex": 0, "tooltip": { "enabled": true, "text": "{name}: [bold]{valueY}[/]", "cornerRadius": 3, "pointerLength": 4, "background": { "color": "", "opacity": 1 } }, "render": "candlestick", "candlestick": { "open": { "x": "date", "y": "open" }, "high": { "x": "date", "y": "high" }, "low": { "x": "date", "y": "low" }, "appearance": { "fill": { "color": "", "opacity": 1 }, "stroke": { "color": "", "opacity": 1, "width": 1 }, "stacked": false, "deriveFieldsFromData": { "fill": { "color": "", "opacity": "" }, "stroke": { "color": "", "opacity": "", "width": "" } }, "heatRules": { "enabled": false, "max": "", "min": "", "dataField": "" } } }, "column": { "open": { "x": "", "y": "" }, "appearance": { "fill": { "color": "", "opacity": 1 }, "stroke": { "color": "", "opacity": 1, "width": 1 }, "stacked": false, "width": null, "height": null, "deriveFieldsFromData": { "fill": { "color": "", "opacity": "" }, "stroke": { "color": "", "opacity": "", "width": "" } }, "heatRules": { "enabled": false, "max": "", "min": "", "dataField": "" } } }, "line": { "open": { "x": "", "y": "" }, "appearance": { "connect": true, "tensionX": 1, "tensionY": 1, "minDistance": 0.5, "stroke": { "width": 3, "opacity": 1, "color": "", "dashArray": "" }, "fill": { "opacity": 0, "color": "" }, "bullets": [ { "enabled": false, "render": "circle", "width": 10, "height": 10, "label": { "text": "{value}", "position": { "dx": 0, "dy": 0 } }, "fill": { "color": "", "opacity": 1 }, "stroke": { "color": "", "opacity": 1, "width": 1 }, "rotation": 0, "tooltip": { "enabled": true, "text": "{name}: [bold]{valueY}[/]", "cornerRadius": 3, "pointerLength": 4, "background": { "color": "", "opacity": 1 } }, "deriveFieldsFromData": { "fill": { "color": "", "opacity": "" }, "stroke": { "color": "", "opacity": "", "width": "" }, "rotation": "" }, "heatRules": { "enabled": false, "max": 100, "min": 2, "dataField": "" } } ] } }, "stepLine": { "open": { "x": "", "y": "" }, "appearance": { "connect": true, "tensionX": 1, "tensionY": 1, "minDistance": 0.5, "stroke": { "width": 3, "opacity": 1, "color": "", "dashArray": "" }, "fill": { "opacity": 0, "color": "" }, "bullets": [ { "enabled": true, "render": "circle", "width": 10, "height": 10, "label": { "text": "{value}", "position": { "dx": 0, "dy": 0 } }, "fill": { "color": "", "opacity": 1 }, "stroke": { "color": "", "opacity": 1, "width": 1 }, "rotation": 0, "tooltip": { "enabled": true, "text": "{name}: [bold]{valueY}[/]", "cornerRadius": 3, "pointerLength": 4, "background": { "color": "", "opacity": 1 } }, "deriveFieldsFromData": { "fill": { "color": "", "opacity": "" }, "stroke": { "color": "", "opacity": "", "width": "" }, "rotation": "" }, "heatRules": { "enabled": false, "max": 100, "min": 2, "dataField": "" } } ] } } } ], "dataSources": { "example": [ { "close": 6, "date": "2021-8-12 15:37:19", "high": 7, "low": 2, "open": 5 }, { "close": 7, "date": "2021-8-13 15:37:19", "high": 9, "low": 5, "open": 6 }, { "close": 5, "date": "2021-8-14 15:37:19", "high": 7, "low": 4, "open": 7 } ] } }, "meta": { "name": "XYChart_0" }, "position": { "x": 141, "y": 103, "height": 375, "width": 435 }, "custom": {} } ] ```
