--- title: "Parameterized Popup Window" --- # Parameterized Popup Window > >
## Overview A parameterized popup window lets you pass parameters from one window into a Popup Window, where the receiving window would display relevant information. Also, this allows you to maintain a single window that can be used to display similar information. For example, suppose you have 2 compressors: Compressor 1 and Compressor 2. Imagine clicking a compressor on your main window and a popup displays the diagnostic information about the compressor. What is passed is simply the compressor number, therefore a single diagnostic window can represent many different compressors. ### Passing Parameters to a Popup Window To pass parameters from one window to a Popup Window, the receiving Popup Window must have Custom properties that receive the passed parameters. When the event on the parent window is called, the parameters are passed to the receiving Popup Window's custom properties on its Root Container. The component's properties on the receiving window can use the Root Container's Custom properties to address their bindings. This example shows how to setup a main window and a popup window to pass compressor numbers to the Popup Window in order to display relevant information about each compressor. ### Setting up the Main Window The Main Window uses buttons to switch between compressors. 1. In a Main Window (parent window) drag a **Button** from the component palette to your window and call it '**Compressor 1**'. ![Setting up the Main Window Step 1](setting-up-the-main-window-step-1.png) 2. Add a custom property which will pass the compressor number to the popup window. Right click on Compressor 1, select **Customizers** > **Custom Properties**. Specify the property named '**Compressor**' with a datatype of '**Integer**' and click **OK**. ![Setting up the Main Window Step 2](setting-up-the-main-window-step-2.png) The Compressor property is now created and displayed in blue in the Property Editor under **Custom Properties**. ![Setting up the Main Window Step 2b](setting-up-the-main-window-step-2b.png) 3. Now, create a second compressor button. A quick way to do this is duplicate (**Ctrl+D**) the Compressor 1 button so it inherits the custom property, and label it '**Compressor 2**'. ![Setting up the Main Window Step 3](setting-up-the-main-window-step-3.png) 4. From the **Property Editor**, change the values for each of the compressors to represent Compressor 1 and Compressor 2, respectively: 1. For the Compressor 1 Button, change the value to '**1**'. ![Setting up the Main Window Step 4a](setting-up-the-main-window-step-4a.png) 2. For the Compressor 2 Button, change the value to '**2**'. ![Setting up the Main Window Step 4b](setting-up-the-main-window-step-4b.png) ### Setting up the Popup Window 1. Drag **Compressor** and **Label** components from the component palette to your window. Rename the Label component to '**Compressor**'. ![Setting up the Popup Window Step 1](setting-up-the-popup-window-step-1.png) 2. Now, create a custom property on your Popup window that will receive the passed parameters. Right click on your window and select **Customizers** > **Custom Properties**. The Custom Properties window will be displayed. Specify a **Name** for the **Custom Property**, for example, name it `compNum`, and click **OK**. ![Setting up the Popup Window Step 2](setting-up-the-popup-window-step-2.png) The **Custom** property is created and displayed in blue at the bottom of the **Property Editor**. :::note Do not bind these **Custom** properties to anything, leave them unbound so you can pass values into them without any other values to override them. ::: 3. Let's use an expression on the Label to change the compressor number. 1. Select the **Label** and click the binding icon for the **Text** property. 2. Select **Expression** for the binding type. 3. Click the **Link icon** ![Link icon](link-icon.png) in the Expression window and choose the '**compNum**' custom property on the root container for the compressor popup window as shown in the screenshot below. You can also copy and paste the expression from the Code Block as shown below. ![Setting up the Main Window Step 3c](setting-up-the-main-window-step-3c.png) ```js title="Script to change the compressor number" "Compressor " + {Root Container.compNum} ``` 4. One last thing to do, add the script to the buttons which read the custom property. This changes the value on the custom property from Compressor 1 to Compressor 2 or visa versa when you press the compressor buttons. 1. Go to your **Main Window**, right click on the **Compressor 1 button** and select **Customizers** > **Scripting**. 2. Select **Open/Swap** navigation. 3. Enter your **window path** for your Popup Window (i.e., Popups/Compressor Popup). 4. Check the **Pass Parameters** box. Click the **green plus** ![green plus](green-plus.png) to add a parameter, which will add a row to the table. 5. Click the new row under **Parameter Name** and a dropdown list will appear. Ignition will automatically check the Root Container of the window selected in the **Window** dropdown. If you do not see the '**compNum**' parameter, it may have been created on wrong component, so check the Root Container of the Compressor Popup window. Select the custom property '**compNum**'. 6. With the row highlighted, click the **Link icon** ![Link icon](link-icon.png) and navigate to the folder where the compressor buttons are located and select the '**Compressor**' custom property. Press **OK** twice. Repeat this step for the Compressor 2 button. ![Setting up the Main Window Step 4f](setting-up-the-main-window-step-4f.png) 5. **Save** your project. ### Test the Project 1. Go to **Preview Mode**, and from your Main Window, click on **Compressor 1**. Your Popup Window will open and display Compressor 1. ![Test the Project Step 1a](test-the-project-step-1a.png) ![Test the Project Step 1b](test-the-project-step-1b.png) 2. Go back to your Main Window and click on **Compressor 2**. This time, your Popup Window will open and display Compressor 2. ![Test the Project Step 2](test-the-project-step-2.png)
