--- title: "Working with Components" --- # Working with Components > There are a number of different ways to select components within a window, each of which have their own advantages. ## Selecting Components ### Mouse Selection Using the mouse is the most common way to select components. Make sure that the selection tool (![selection tool](selection-tool.png)) is the active tool. Simply click on a component to select it. If the component you want to select is obscured by other components, hold-down **Alt** and keep clicking, the selection will step down through the z-order. You can also select components using window-selection. Click-and-drag within a container to draw a selection rectangle. If you drag the window **left-to-right**, it will select all components that are **completely contained within the rectangle**. If you drag the window **right-to-left**, it will select all components that **the rectangle touches**. Lastly, you can start dragging a window selection and then hold-down the **Alt** key to use touch selection. This will draw a line as you drag, and any components that **the line touches** will become selected. As you're using these techniques, components that are about to become selected will be given a yellow highlight border. ### Tree Selection By selecting nodes in the **Project Browser** tree you can manipulate the current selection. This is a handy way to select the current window itself, which is hard to click on since it is behind the Root container. However, you can click to it, using **Alt-click** to step down through the z-order. It is also the only way to select components that are invisible. ## Manipulating Components Manipulating components can be done with both the mouse and the keyboard. You can move components around, resize them, and rotate them. ## Resizing When you select the component you want to resize, they'll get 8 resize-handles displayed around the edge of the selection. These handles look like double-sided arrows around the perimeter. Use the mouse to drag them to change the size of the components in the selection. To maintain the selection's aspect ratio, hold down **Ctrl** as you resize. To resize around the center of the current selection, hold down **Shift**. These can be used at the same time. You can also resize the current selection using the keyboard. To nudge the right or bottom edge of the selection in or out, use **Shift** combined with the arrow keys. To nudge the top or left edge of the selection, use **Ctrl-Shift** combined with arrow keys. These nudge actions will resize one pixel at a time. To resize faster, use the **Ctrl-Shift-Alt** key, to move the component ten pixels at a time. ### Moving To move the component, simply drag it anywhere within the container's bounds. You can also move whatever is currently selected by holding down **Alt** while dragging, regardless of whether or not the mouse is over the current selection. This is important because it is the primary way to move a Container component (normally, dragging in a container draws a selection rectangle inside that container). While a component is selected, you may also use the keyboard's arrow keys to move a component around. The arrow keys will move the selection one pixel at a time. Just like resizing with the arrow keys, to move faster, use the **Ctrl-Shift-Alt** key. ### Duplicating Components can be easily duplicated by dragging them as if you were going to move them and holding down the **Ctrl** key. This will drop a copy of the component at the desired drop location. It is often useful to also hold down **Shift** key as you do this to ensure exact alignment. You may also use the **Ctrl-D** shortcut to quickly duplicate a component in place. ### Rotating Shapes can be rotated directly using the selection tool. Other components cannot be rotated in this manner. To rotate a shape, first select it using the selection tool so that you see the resize handles around it. Then simply click on it once again and you'll see the rotation handles appear. Clicking (but not double-clicking) on selected shapes toggles back and forth between the resize handles and the rotation handles. Once you see the rotation handles, simply start dragging one to rotate the shape or shapes. Holding down the **Ctrl** key will snap your rotation movements to 15° increments. When the rotation handles are present, there is also a small red crosshair handle that starts in the middle of the selection. This is the rotation anchor: the point that the selection will rotate around. You can drag it anywhere you'd like to rotate around a point other than the center of the shape. See also: [Component Animation](visualization-and-dashboards\understanding-components\component-animation\component-animation.md) ## Component Grouping Shapes and components can be grouped together so that they act like a single component in the Designer. Grouping components is very similar to putting them in a Container. In fact, it is the same thing as cutting and pasting them into a perfectly-sized container and then putting that container into group mode, with one exception. If the group contains only shapes and no other kinds of components, it will be a special shape-group that has the ability to be rotated and has some other shape-like properties. When components or shapes are in a group, clicking on them in the Designer will select the group instead of the shape. If you double-click on a group, it will become "super-selected", which will allow you to interact with its contents until you select something outside of that group. Groups can contain other groups, creating a nested structure. Groups themselves are also components, meaning that you can add custom properties to groups, bind them, and so on. ### Difference Between a Container and a Group It is helpful to use Groups and Containers to organize the components on your window. You can select multiple components and right-click to convert them into a group, then right-click again convert that group to a container. ![Difference Between a Container and a Group](difference-between-a-container-and-a-group.png) **Layout works differently for groups**. The layout setting for components and shapes inside a group is **ignored**. All members of a group act as if they are in relative layout with no aspect ratio restrictions. This special group-layout mode is also active when resizing a group inside of the Designer, whereas traditional (container) layout doesn't take effect in the Designer. ## Component Layout Layout is the concept that a component's size and position, relative to its parent container's size and position, can be dynamic. This allows the creation of windows that resize gracefully using either **Anchored** or **Relative** layouts and can optionally keep the original aspect ratio. This is a very important concept because of the web-launched deployment of Vision clients - they often end up being launched on many different monitors with many different resolutions. This is also important for components that have user-adjustable windows like popup windows. Imagine a popup window that is mostly displaying a large table or chart. If you're running on a large monitor, you may want to make the window bigger to see the table or chart easier. Of course, this is only useful if the table or chart actually gets larger with the window. Changing a component's layout is as simple as right-clicking on the component and opening the Layout dialog box. You can also alter the default layout mode that gets assigned to new components. See [Designer/Window Editing Properties](projects\project-properties\project-properties.md#designer---window-editing-properties). There are two layout modes, and they are set on a per-component basis. Both affect the component's size and position relative to its parent container. The root container's size is dictated by the window size. To edit the layout of a component, right-click on the component and select **Layout** from the menu. The Layout Constraints window displays showing all the default settings. These default settings can be altered in the Project Properties. ![Component Layout](component-layout.png) ### Layout Modes * **Relative** - This mode makes a component's size and location relative to its parent's size and location. When the parent changes size, the component changes accordingly. This creates components that auto-scale. * **Anchored** - This mode makes the edge of a component's two axes (horizontal and vertical) anchored to the edge or edges of its parent. ## Relative Layout Relative Layout is the default mode. This is a simple and effective layout mode that simply keeps a component's size and position constant relative to its parent container, even when the parent container grows or shrinks. More precisely, it remembers the component's position and size as a percentage of its parent's bounds at the last time the window was saved. Relative Layout also has the option of scaling a component's font appropriately. ![Relative Layout A](relative-layout-a.png) Note, that Relative Layout mode respects aspect ratio. So if the parent component is distorted, the contents will not be. The extra space is distributed evenly on both sides of the contents. ![Relative Layout B](relative-layout-b.png) ### Relative Layout Options * **Maintain Aspect Ratio** - If selected, the component's original aspect ratio is preserved. Otherwise, it can stretch tall or wide. * **Center** - When maintaining the aspect ratio, centers the component with respect to its parent. * **Leading** - When maintaining the aspect ratio, aligns the component with the paper leading edge. * **Trailing** - When maintaining the aspect ratio, aligns the component with the parent's trailing edge. * **Scale Font** - If selected, the component's font will scale along with its size as the relative layout adjusts the component. This will override other font size settings. If this setting is applied to a Group, then all components in the group will use this setting. ### Font Scaling By default, font scaling is enabled on all components, but it can behave differently on some components so it’s good to test it out before putting it into production. You can change the default Component Layout settings in **Project Properties** under **Designer** > **Window Editing**. #### Font Scaling on Individual Components When individual components are dragged into a window, the following default Layout settings for each component are applied. All components on the window default to font scaling. ![Font Scaling on Individual Components](font-scaling-on-individual-components.png) #### Font Scaling on Groups When individual components are grouped together, the default Layout settings are applied to the new group component, and to each component in the group. All the components in the group default to font scaling. ![Font Scaling on Groups 1](font-scaling-on-groups-1.png) Font scaling on individual components in a group can be disabled by selecting the group, and double clicking on a single component. You will get a red outline around the group, then you can select the individual component(s), and disable font scaling. :::note The individual component font scale setting takes precedence within a group. ::: ![Font Scaling on Groups 2](font-scaling-on-groups-2.png) When you remove the group (right-click and select **Ungroup**), all the individual components within that group will get reset to the default Layout settings including font scaling, even if font scaling was set differently. ![Font Scaling on Groups 3](font-scaling-on-groups-3.png) #### Font Scaling on Containers You can convert a group to a container to change the way scaling works. Ignition remembers the last Layout Settings you made to each individual component in that group prior to the conversion to a container (i.e., if any of the components had font scaling disabled, once the group is converted to a container, those same components will still have font scaling disabled). ## Anchored Layout Anchored Layout lets you specify various "anchors" for the component. The anchors dictate how far each of the 4 edges of the component stay from their corresponding edges in the parent container. ### Anchored Layout Options * **North/South** - If one of these is selected, the distance between that edge of the component and that edge of the container is preserved. If both are selected, the component will stretch its **height** to maintain both distances. * **West/East** - If one of these is selected, the distance between that edge of the component and that edge of the container is preserved. If both are selected, the component will stretch its **width** to maintain both distances. * **Center Vertically** - When selected, both top and bottom buttons will be deselected. This option maintains the height of the component and centers it **vertically** in the container. * **Center Horizontally** - When selected, both left and right buttons will be deselected. This option maintains the width of the component and centers it **horizontally** in the container. ![Layout Anchor Options](layout-anchor-options.png) For example, if you anchor top and left, then your component will stay a constant distance from top and left edges of its parent. Since you didn't specify an anchor for the right or bottom sides, they won't be affected by the layout. ![Layout Anchor Options Position 1](layout-anchor-options-position-1.png) If you anchor bottom and right instead, the components will again stay the same size (since you didn't specify an anchor for their other edges, but they will stay a constant distance from their parent's right and bottom edges). ![Layout Anchor Options Position 2](layout-anchor-options-position-2.png) Of course, you can mix and match the various modes for the different components in a given container. The following image shows the following: * The **square** uses a horizontal and vertical centering anchor. It is centered, and stays the same size. * The **triangle** is anchored south and west. * The **circle** is anchored north, west, south, and east. This means that its edges are all anchored and stay a fixed distance to each of its parent's edges, so it grows. ![Layout Anchor Options Position 3](layout-anchor-options-position-3.png)
