title: "HTML in Ignition"
# HTML in Ignition
## Using HTML in Components
Many Ignition components display a text string. By default, a component's text is displayed in a single font and color and will not wrap when its content exceed the space the component has made available to the text.
HTML stands for HyperText Markup Language. It is commonly used to style text within webpages. The features that HTML brings to style web pages can be applied to many components within Ignition to style the text within components.
You can use HTML if you want to mix fonts or colors within the text or if you want formatting such as multiple lines. HTML formatting can be used in Ignition components such as buttons, labels, and tables. It can be used in common properties such as the mouse over text property.
To specify that a component's text has HTML formatting, just put the `` element at the beginning of the text, then use any valid HTML element in the remainder.
:::note
Closing the HTML element is optional. In other words there is no need to place a `` at the end of your stylized text. Also, the HTML elements are not case sensitive.
## Common HTML Elements
HTML tags are the special characters that instruct text to become stylized differently than other text within the same text. The following table describes the most common HTML elements that you can use within Ignition.
| HTML Element | Name | Description |
| <html>...</html> | HTML | Initiates an html formatting. In most cases, closing the html with </html> is optional. |
| <b>...</b> | Bold | Applies a bold style to the contents of these elements. |
| <u>...</u> | Underline | Underlines the text contained within the elements. |
| <s>...</s> | Strikethrough | Draws a line through the text contained within the elements. |
| <br> | Break | Applies a line break at this specific location. |
| <ol>...</ol> | Ordered List | Places the text into an ordered list. Text inside list items are ordered by number. |
| <ul>...</ul> | Unordered List | Places the text into an unordered list. Text inside list items are ordered by bullets. |
| <li>...</li> | List Item | Used to represent a list item. Should be contained in an order list (<ol>) or unordered list (<ul>). |
| <center> | Center | Centers the contents of the text. Used directly after the HTML tag (that is, <html><center>...) |
| <font color="red">...</font> | Font | Colors the contents red. Works with standard color names, hex numbers, or RGB numbers. |
## Applying HTML to Components
In Ignition, you can add HTML to the text property of any component such as, a label, button, or table. These examples aren't unique to their specific components, but can be used on any component that has a Text or Mouseover Text property.
### Adding HTML into a Label
Instead of having a long label, you can have it auto wrap text by simply adding `<\html>` to the beginning of its text property.
1. Select the label that needs the automatic line wrapping.
2. Select the component's Text property.
3. Insert `` before the start of the text and press enter.
Or, supposed you want to make a label appear like this: This is a **bold** word
1. Create a label on your window.
2. Select the label's text property and enter the following text:
```html
This is a bold word
And if you wanted to have a line break in a specific spot in the text.
1. Create the label and select the Text property.
2. Insert `` before the start of the text. Select the part of the text that you want to see the break occur and type `
` in this location and press enter.
```html
I would like to have a new line
so that the rest of my text will be below it.
### Adding HTML into a Button
Suppose you want to make a button appear with Stop the Process, with the word `process` appearing in red. The word "Process" starts on a new line. Also, the words must be centered on the button.
1. Create a button on your window.
2. Select the buttons text property and enter the following text:
```html
